It is currently Fri Aug 15, 2025 11:11 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 12, 2012 8:03 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
meddlingfool wrote:
Why would a thin film of epoxy be any worse for tone than a layer of lacquer/poly/shellac/whatever?
Take a thin sheet of paper, and coat each one in epoxy, lacquer, shellac. That shoud answer the question.
PostPosted: Tue Mar 13, 2012 8:46 am
CharlieT wrote:
Mark Groza wrote:
I've use zpoxy on my rosettes to get a good porefill on porous wood, but i don't put it on the whole top. I also sand back to the wood after porfilling and have no problem with uneven shades on the top around the rosette from the zpoxy. System three might be different though as i don't use that because it's not as clear as zpoxy.
Mark - when you say S3 is not as clear as Z-Poxy, are you referring to the amber tint, or something else? S3 is much clearer that Z-Poxy in the sense that it has virtual no amber to it at all, whereas the Z-Poxy has a very noticeable amber tint to it, so I'm a little puzzled by your comment.
I 've heard that system3 had an amber tint to it so i have never used it. The zpoxy i've used is totally clear.
PostPosted: Tue Mar 13, 2012 10:16 am
Another option for pore filling rosettes is to apply CA after a thin coat of finish. I use Bob Smith Industries Gold medium viscosity odorless CA. It will stick just fine to sanded waterborne, but you can't do the same with epoxy. I let it cure for a few days before leveling and continuing with my finish, though I don't usually use a waterborne. I don't have a problem with contaminating the top with my pore fill with this method.
Ken Franklin
clumsy yet persistent
PostPosted: Tue Mar 13, 2012 11:37 am
Filippo Morelli wrote:
Darrel Friesen wrote:
Filippo, did you go straight up with the redwood or did you laminate with spruce or some other? Sounds like you used it on it's own. I only ask as I have a top that I'm looking to use on a current build. Looks good with none of the micro-cracking that I've read about recently on other threads. I'd prefer not to laminate and may try the zpoxy thing on this top.
Darrel - I didn't laminate.
Filippo
Thanks Filippo. I'll be doing it without laminating as well. I just recall Harry Fleischman's article in GAL where he let the beauty of the curly redwood blind him and ended up having to retop his harp guitar. I've always had a bit of a devil may care attitude. the guitar is for me, so I'm not worried. Anyway, verging on derailing this thread from the OP question.
PostPosted: Tue Mar 13, 2012 1:40 pm
[quote="Todd Stock"]Sure you are using the finishing resin? Z-Poxy Finishing Resin has a hardener that (like West 205 & 206) darkens over time from medium amber to dark amber...the lightest I've ever seen is a very fresh batch that was still medium amber.
The System 3 standard resins and T-88 both have straw colored hardeners that darken to a deep amber over time - especially if stored in metal containers. System 3 Clearcoat finishing resin is essentially crystal clear (although very, very picky about mixing) - it's a good filler. Finally, West has 207 hardener that is supposed to be clear, but still darkens to a straw or amber pretty quickly.
I like the slight amber color of Z-poxy on most woods - it warms up rock maple enough to avoid having to put some color in the toner, and adds a lot of depth to ash, oak, Yes, I don't use system three a don't know anything about it. I just know i don't have any problem with the amber color on a top next to the rosette when i pore fill with it.
PostPosted: Wed Mar 14, 2012 5:40 am
First name: James
Last Name: Lee
City: Atmore
State: AL
Zip/Postal Code: 36502
Thank you to everyone who reply'd. I think I will try to avoid using the epoxy on the top as much as possible. If I do, I will try to thin it down with alcohol like was suggested.
Thanks again
-James
PostPosted: Wed Mar 14, 2012 7:12 am
Last Name: O'Melia
City: Huntsville
State: Alabama
And consider using a clear epoxy for that.
PostPosted: Wed Mar 14, 2012 7:18 am
How do you all apply it? With a stiff card or such a thing? Wipe across or with the grain?
PostPosted: Wed Mar 14, 2012 8:04 am
Todd Stock has a good tutorial in the vids and tutorials section and uses a small squeegee. The only thing I would caution is being careful on the first coat dependent on the type of squeegee as it can leave black marks on the bare wood. DAMHIKT! It does work a lot better than the cards I used to use however.
PostPosted: Wed Mar 14, 2012 10:38 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I bought a box of yellow ones from a auto supply store. Probably never have to buy them again. Nice, thick, tapered, and easy to clean. Rounded corners to keep from marring the wood.
PostPosted: Wed Mar 14, 2012 2:15 pm
First name: James
Last Name: Lee
City: Atmore
State: AL
On The system three bottle it says the mix ratio is 100:44 by weight. Am I figuring correctly saying that if I mix one gram of hardener I would Use 2.27 grams of Resin. Also is this the best Ratio?
PostPosted: Wed Mar 14, 2012 3:48 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Todd Stock wrote:
Mike:
The Bondo spatulas are what I used to use and they are both cheap and effective, even if they get ragged pretty fast. For working epoxy in and taking the excess off, the thick-bladed industrial-grade rubber squeegees give you a lot more control and greater ability to really load the blade to force the epoxy into the pores and to skim off the excess. The Etore squeegees are to spatulas as spatulas are to cheap credit cards...it's what allows me to get such a thin, consistent coat of epoxy on without lines or runs, etc.
Seriously - you will love the Etores - they make epoxy work easy.
Well, with that kind of endoresment I will most certainly be getting some. Cause if there is one thing I hate doing , its messing with epoxy. Thanks Todd. [:Y:]
