It is currently Sat Jun 28, 2025 5:57 pm
 Post subject: Cutting Binding Strips
PostPosted: Sun Jul 22, 2012 5:27 pm
First name: Darryl
Last Name: Young
State: AR
Been away for awhile but hopefully I'll now be able to hang out a bit more.
I will soon be cutting binding strips for the Cuban Mahogany 00 I'm building and this will be the first time I've used wood binding. I bought a beautiful Cocobolo binding stip from Hibdon Hardwood that is 0.096" thick and a little over 1.5" wide and I need to cut it up into binding strips. So I have a couple of questions about binding sizes and the best way to cut these strips.
- Should I thickness then cut into strips or cut into strips then thickness in my drum sander? What thickness would you recommend for binding, 0.062"?
- What's the best way to cut into strips? I have a thin kerf, circular saw sized Diablo blade I can use on my table saw. Can I use a zero clearance insert with that blade? Can I get by with setting the fence at the desired width of the binding and cutting the strips between the blade and the fence (set the fence one time and cut all the binding strips)?
- Finally, what width binding looks good and does anyone change the width of the binding depending on the body size? I'm leaning toward 0.200" width but I'm open to suggestions.
PostPosted: Sun Jul 22, 2012 5:38 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
My wood bindings are 0.075" by 0.340". That height includes the side purflings which are about 0.064in height so the actual binding is about 0.275". I would thickness after cutting. I used to cut all this on the bandsaw, but Todd convinced me to use a 7-1/4" plywood blade in my table saw for the job and I've been happier with the results. I use a zero clearance and cap the exposed blade above the work with a scrap of wood clamped to the fence, this keeps the thin stock from climbing off the blade and improves the quality of the cut.
Brian
PostPosted: Sun Jul 22, 2012 5:45 pm
You could use a slitter something like this, which would give you two pieces per set up. I've used it to cut wood bindings and there's no loss to kerf!
viewtopic.php?f=10117&t=19132
If I use a tablesaw, I cut "outside" & reset the fence each time......... definitely safer & you don't explode any.
Either way, I'd pre-thickness with "luthiers friend".
Milton, ON
PostPosted: Sun Jul 22, 2012 5:53 pm
Last Name: Ensor
City: Springfield
State: Missouri
I thickness the whole blank first. I then cut to width. Mine are generally .080" in thickness and .280" in height. I don't stick to the height measurement very strictly, just kinda what I am feeling like for the build. I use my fret saw blade to slice them up on the table saw. I cut just a bit taller than I need and then sand them to the height I want in my drum sander.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Sun Jul 22, 2012 5:55 pm
First name: Darryl
Last Name: Young
State: AR
B. Howard wrote:
....... I use a zero clearance and cap the exposed blade above the work with a scrap of wood clamped to the fence, this keeps the thin stock from climbing off the blade and improves the quality of the cut.
That is a great suggestion, thanks!
PostPosted: Sun Jul 22, 2012 7:35 pm
Online
City: Quakertown
State: Pa
Pictures?
PostPosted: Sun Jul 22, 2012 9:35 pm
First name: Darryl
Last Name: Young
State: AR
Dave, thanks for that link! Just finished reviewing it and it seems a neat method to try.
PostPosted: Sun Jul 22, 2012 9:36 pm
I'm looking into having a blade custom made. A 6" rip blade with about a .040 kerf. A bit expensive on the frontside expenditure, but sure would save a lot of wood going up the dust chute... Hmmmm....group buy?
PostPosted: Sun Jul 22, 2012 9:37 pm
First name: Darryl
Last Name: Young
State: AR
Thanks for those dimensions and procedure Todd.
PostPosted: Sun Jul 22, 2012 9:42 pm
First name: Darryl
Last Name: Young
State: AR
Chris, thanks for sharing the dimensions you use. I'm a little torn on how wide to make these bindings. 0.200" is the minimum.
PostPosted: Tue Jul 24, 2012 10:59 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I always cut my strips on the bandsaw. Oversized. I do get the thickness right before I slice. Then, after cutting on bandsaw, I pass them together through the thickness sander to get them all to the same height.
PostPosted: Tue Jul 24, 2012 12:33 pm
First name: Darryl
Last Name: Young
State: AR
Thanks for your comments meddlinfool and Mike.
Mike, if I understood correctly, you stack all the binding strips together and sand to the correct width (the 0.2-0.28 dimension)? I was wondering if that was doable so thatnks for pointing that out. I guess I could cut leave the thickness slightly oversize, cut the width slightly oversize, then sand width and thickness to final dimensions on the drum sander.
PostPosted: Thu Jul 26, 2012 9:12 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Yes, stack sideways, and do passes on each side until all saw marks are gone. Don't work just one side. Make sure you rotate so that all possible pass directions happen. This way, they won't get "canted" on an edge. Try to maintain the stack order (not hard to do). And, cut your strips oversize. Already thinned and sanded to proper thickness. I never thin to desired thickness nor sand height to desired height. I want the installed piece to be proud on all edges, Then I scrape and sand to final look.
PostPosted: Thu Jul 26, 2012 9:32 am
Last Name: O'Melia
City: Huntsville
State: Alabama
What about this blade? Bad idea?
http://www.stewmac.com/shop/Tools/Speci ... 3&xsr=4330
(but seriously, I can do the same or close on my bandsaw, and then sand. If it's the waste of the wood you are worrying about, then a thin kerf blade may be the way to go)
PostPosted: Thu Jul 26, 2012 11:04 am
Bad idea, it will overheat (damhik).
PostPosted: Thu Jul 26, 2012 1:20 pm
I have used it a few times, I use it to rip all my purflngs, and I use it regularly to make binding if I'm cutting them out of side scrap. I use the LMI one, which won't give enough height above the table to rip a 1/4" purfled binding blank. Plus, it's a cross it blade, and yes it does overheat, and you need to stop every now and then to clean off resin.
I basically want a rip version of that blade. But I was quoted 250$ a blade, kinda steep...
PostPosted: Thu Jul 26, 2012 5:19 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I asked some folks at SMC, here is a suggestion:
http://www.carbideprocessors.com/tenryu ... saw-blade/
at 5/64" kerf (smidge over 1/16"), it's a tad over twice the 1/32" kerf from Stew Mac.
But it is not crazy priced either. And it is a ripping blade. Amazon has more Tenryu listings.
These guys have a 1/16" kerf (no sure if for ripping)
http://www.infinitytools.com/Laser-Thin ... ucts/1800/
but they are getting into the crazy price regime. Maybe that Tenryu is the way to go?
PostPosted: Thu Jul 26, 2012 11:43 pm
First name: Darryl
Last Name: Young
State: AR
I have the Diablo on-hand and will likely be using it. My biggest worry is chip out while ripping (the strip from Hibdon is so thin).
PostPosted: Fri Jul 27, 2012 9:29 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Do you mean this blade?
http://www.diablotools.com/blades-7.html (Freud Diablo Part# D0724X/A)
PostPosted: Fri Jul 27, 2012 9:37 am
First name: Darryl
Last Name: Young
State: AR
This is the one I have and I think it's the one Todd is referring to:
PostPosted: Fri Jul 27, 2012 10:36 am
If I do bindings like that, which I don't do much anymore as I prefer to cut them on a band saw from a block, I would thickness first and then cut with a knife. Clamp a straight edge to the sheet and run a razor blade over it maybe 6 or 7 times to free it.
But I don't have a table saw ;)
PostPosted: Fri Jul 27, 2012 1:26 pm
+ another on the Freud Diablo in 7-1/4" x 40 tooth. Used with a zero clearance insert.
PostPosted: Fri Jul 27, 2012 2:01 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Yup. Gotta use a ZCI or your will never accomplish much except tear up your wood. ;)
PostPosted: Tue Aug 14, 2012 8:57 pm
First name: Darryl
Last Name: Young
State: AR
Cut the Cocobolo binding strips tonight. I had bought a practice side from RCT and it was white oak so I thiined it and practiced cutting strips from it first. It went well so I thinned the Cocobolo and tried it. It went pretty nice. Only issue I had was the stip was only 1.5" wide and unfortunately, the sides werent flat so I had to get them flat and I barely had enough wood left to cut 5 binding strips.......but I made it.
I used the dimensions Todd suggested, used a zero clearance insert, used a wood block clamped to the fence on top of the strip, and used the Freud blade shown above. Turned out nice and I sure appreciate the tips!
PostPosted: Tue Aug 14, 2012 10:39 pm
First name: Nelson
Last Name: Palen
This binding cutting setup uses a .030" x 1.25" blade mounted on a pneumatic die grinder which travels manually on a single linear way. The material being cut is held stationary by a couple cam clamps. One of the two tab stops is shown in the picture and is adjusted with a 10-24 screw at the other side of the table. The table will hold a 2'x4' sheet. The .030 blade is flat ground carbide which leaves a nice square edge on wood but ABS requires deburring with a scraper.
Edit: Blade guard has been removed for photo.
