It is currently Sun Jun 29, 2025 10:18 pm
PostPosted: Wed Aug 15, 2012 9:12 am
Anyone have ideas on the purchase or fabrication of a houndstooth-patterened purfling? TIA.
PostPosted: Wed Aug 15, 2012 4:26 pm
Anybody? (bump)
PostPosted: Wed Aug 15, 2012 4:46 pm
Last Name: Kincheloe
What exactly do you want it to look like in purfling form? The picture of houndstooth on wikipedia looks like it's more of a surface-covering pattern, than a fine line pattern. But in any case, it looks like it's just solid black and white squares, alternating with stripey squares that could be made by layering up different thickness veneers and then cutting it diagonally to rotate the lines by 45 degrees.
PostPosted: Wed Aug 15, 2012 10:11 pm
Dennis,
I think that's the track my imagination is taking as well...I'm planning a 'Crimson Tide" themed guitar and we're undecided on which elements should make it into the finished instrument. Houndstooth seems like a must, and we are thinking rosette (which seems the safe and obvious choice) or the more understated top border where the pattern would be used in lace of abalone or simple purfling lines.
PostPosted: Wed Aug 15, 2012 10:32 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
Man, you have GOT to post pics of that thing! You have me intrigued...for instance, are you going to use bloodwood for the back and sides?
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Thu Aug 16, 2012 3:49 am
Lar, it looks like one element shape, in a two color layup, repeated 4 times.
I've laid out the process as I see it.
PostPosted: Thu Aug 16, 2012 6:44 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
That looks like the easiest way to lay it up. To have it recognizable as houndstooth, it would need to be layered in multiples of four. 12-16 layers would look great.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Thu Aug 16, 2012 7:16 am
Last Name: Killin
Just make sure whatever wood you use for Red doesn’t, overtime, fade to Orange. That would probably work against your theme.
gaah gaah gaah gaah
laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Thu Aug 16, 2012 9:36 am
First name: Stephen
Last Name: Sill
City: The Colony
Zip/Postal Code: 75056
If it fades to orange, hopefully it will be kind of a burnt orange. Then the good Texas college will have a guitar. Hahaha
Stephen
PostPosted: Thu Aug 16, 2012 11:07 am
Phil - the back and sides will likely be maple, with a transparent dye for color...
Billy T - you always amaze me! I'm not even going to ask how you modeled that so quickly!
John - What an "Au-ful" possibility! :D
Stephen - don't get me started!
PostPosted: Thu Aug 16, 2012 11:55 am
L. Presnall wrote:
...Billy T - you always amaze me!
Well... People usually say I scare the heck out of them ...I guess that's close! laughing6-hehe
L. Presnall wrote:
I'm not even going to ask how you modeled that so quickly!...
Cause I did it WRONG!! laughing6-hehe
I inadvertently inverted the two center layups! Here's what it should look like!
And here's what they would look like laid together in a full houndstooth. Just in case, I don't know what exactly you're doing.
Here's a picture of where houndsteeth come from!
PostPosted: Thu Aug 16, 2012 12:02 pm
Ha! :D I'm thinking a top border such as one would normally accomplish with herringbone or abalone, but using home rolled houndstooth instead.
PostPosted: Fri Aug 17, 2012 6:40 pm
First name: Stephen
Last Name: Sill
City: The Colony
Sorry, I just couldn't help myself.
Stephen
PostPosted: Sat Aug 18, 2012 2:43 am
That's OK!! Just don't let it happen again!!! laughing6-hehe
Just as long as it's not Tennesee!!!! :D
PostPosted: Sat Aug 18, 2012 3:52 am
First name: Stephen
Last Name: Sill
City: The Colony
Definitely not Tenn. Always a longhorn fan though.
Stephen
PostPosted: Sun Aug 19, 2012 8:40 am
Thanks guys! I'm brainstorming (more of a light drizzle, actually) on what material I'll use to do this...I'm thinking initially of WBW plastic purfling lines and using an exacto to scrape the white off so that I have the segments...then laying up the lines side-by-side for the pattern...but Andy Dufrene tunnneled out of Shawshank with a rock hammer faster than I'll be able to do this...brainstorming continues.... [xx(]
PostPosted: Sun Aug 19, 2012 9:47 am
Last Name: Killin
Looking at Billy T's final pic, what if you just split a piece of Herringbone down the middle than glued the side pieced to another strip (but backwards)? If you are doing black and white, I would think that would work.
PostPosted: Sun Aug 19, 2012 11:29 am
Best bet Lar, is to do a straight layup of flat veneer, fishpaper or plastic and after it sets cut the small strips on the bias. I'm pretty sure the angle is 45º.
I don't know how wide you're planning on making these. That would probably determine what's the best way to approach this as for material and technique.
PostPosted: Sun Aug 19, 2012 11:58 am
Billy, I'm a product of the Alabama Public Education System. 'Laborate a little...I think I'm getting it, but I need another illystrashun...
Users browsing this forum: Jim Watts and 16 guests
