It is currently Mon Apr 27, 2026 12:34 am
PostPosted: Sat Dec 08, 2012 5:23 pm
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
I have a bunch of very nice quilted maple that I have considered using for bindings. I've used curly maple, but not quilted. I'm not sure if it bends as easily or would even look as nice.
Does anyone have any input or examples?
PostPosted: Sat Dec 08, 2012 5:31 pm
First name: D
Last Name: S
The quilted Maple I have bought was plain sawn to emphasize the quilt, so it should bend rather easily.
I have not tried it for binding.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Dec 08, 2012 8:40 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
If the quilt figure is on the large side, you may not see the full effect of the figure
on a 1/4" or so wide binding. Most of the curly maple bindings that I've used have
about 1/8-1/4" spacing between the "curls". That shows up nicely on a binding. If
the quilt figure is 1/2-1" or bigger, I'd worry about seeing the full effect of the figure.
Best way is probably to slice off a small sample of binding sized pieces and see if you
like the effect.
Gene
PostPosted: Sun Dec 09, 2012 8:18 am
I think it would be fine
I would bend 6 pcs hoping for 4 good one
PostPosted: Sun Dec 09, 2012 11:31 am
First name: Danny
Last Name: Vincent
I've never seen it done with Maple but I would do it. Someone posted a pic here of a guitar they did with quilted Sapele or Mahogany and it looked great. You could see the binding had some nice figure.
PostPosted: Sun Dec 09, 2012 10:19 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Use curly for binding. You will find that the quilting will be lost in the smaller scale of binding. Kind of a waste. It will still look good, but not quilted
PostPosted: Mon Dec 10, 2012 2:33 pm
Last Name: Hosmer
Why not use the same method that one would use to determine best visual effect on a back set?
Some people place molds over the back plates to see firsthand how it's gonna look. Some draw outlines.
You can do the same thing with binding. If your binding strips are 1/4" wide, simply cover up the board so that only a long 1/4" wide section is showing.
Two rulers or other straightedge laid on top of the board and spaced a 1/4" apart will work. I've used black construction paper for better isolation/visual focus. Two strips of blue tape works very well and is quick.
Whatever you feel allows you to best focus on how the strip itself will appear once cut to that dimension.
This avoids cutting the wood, preserving the board if you decide you don't like the visual effect.
Do this on both the face and edge of the board. Binding is relatively narrow, so don't overlook using the edge of the board as the face of your binding. Depending on how the board is cut and the grade of the quilting, you could go from a quilted effect to a curly effect.
Always have plenty of sandpaper; it's rough out there!
PostPosted: Tue Dec 11, 2012 12:53 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Here is a photo of flamed maple on a walnut/redwood I build long ago.
Hank Mauel
