It is currently Sat Apr 18, 2026 6:50 pm
PostPosted: Tue Jan 22, 2013 10:15 am
First name: Martin
City: Bandung
Country: Indonesia
could you tell me what kind of router bit that used for making classic guitar bridge, or could you reference some website about making classical guitar bridge ? thank you ... :D
Twitter : @martinbandung
www.martinbandung.blogspot.com
PostPosted: Tue Jan 22, 2013 10:55 am
You can do the whole thing on a table saw.
I believe Bogdanovich does it that way
Much easier IMO
There is a tutorial by GaryL in that section of the board if you want to go with the router
PostPosted: Tue Jan 22, 2013 2:08 pm
I do mine on a Radial Arm saw, then use a chisel to ramp the back of the saddle section, and a plane and file to round off the front. Pretty fast process, really.
PostPosted: Wed Jan 23, 2013 12:43 am
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
I made my bridge mainly on a tablesaw, too. I followed Robbie O'Brien's Youtube video, and even though I had to make a model, and scale everything down (it was a miniature classical I was making), I found the whole process to be enjoyable and move along pleasantly.
If I were to do it again, I would prefer the tablesaw. No jigs required, just setting up the saw.
PostPosted: Wed Jan 23, 2013 8:01 am
First name: Jim
Last Name: Kirby
Tablesaw. I have bridge-sized setup blocks that line up the position and depth of cuts for each different bridge I've made. It takes only a few minutes to get each bridge to the point where it is ready for the chisel and file work mentioned above.
Jim Kirby
kirby@udel.edu
