It is currently Sat May 30, 2026 7:11 pm
Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Jason Moe's Build
PostPosted: Sat Feb 16, 2013 3:13 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Even though nobody cares anymore about this build, i'm finishing it. So I got the purfs and binding done. I used curly sycamore on this. It matches the neck pretty well. ImageImageImageImage 22 hours of shop time.
Jason Moe
LaCrosse WI 54601
PostPosted: Sat Feb 16, 2013 10:13 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I think all of us love peaking at other's builds so keep posting. Looks good so far!
PostPosted: Sat Feb 16, 2013 10:33 am
First name: Big
Last Name: Jim
Keep building it , and posting . I am interested in your work !
PostPosted: Sat Feb 16, 2013 11:00 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
What they said. Show me a close up of curly sycamore.
Bryan Bear PMoMC
PostPosted: Sun Feb 17, 2013 12:37 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Heres a pic of the binding. Image
Jason Moe
LaCrosse WI 54601
 Post subject: Jason Moe's Build
PostPosted: Mon Feb 18, 2013 7:21 pm
First name: Tony
Last Name: C
City: Brooklyn
Nice looking binding.
Posted using something.
http://www.CostaGuitars.com
PMoMC
PostPosted: Sun Mar 03, 2013 11:41 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
I fretted the fingerboard today. ImageImageImageImage
Jason Moe
LaCrosse WI 54601
PostPosted: Sun Mar 03, 2013 11:55 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Nice job on the semi-hemispherical fret end dressing (or, sphed as we call it at my house)! That is a very cool looking fretboard.
PostPosted: Mon Mar 04, 2013 1:55 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Thanks Beth. I dress my ends before I tap them in. After they are all in, I go over them with a small file to touch up and sand with 320 grit sandpaper to make it smooth on your hands. It's a Hickory fretboard and I have some wood left over I might smoke some ribs up with when the guitar is done. Jason
Jason Moe
LaCrosse WI 54601
PostPosted: Sun Mar 24, 2013 11:19 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
I got the bridge done today. I clamped it in my drill press vise, and lined the holes up in a line, so all I have to do is loosen the clamp a little and slide the bridge down. They will all keep in a nice line. Then I shaped on a spindle/drum sander. I forgot to take a picture of slotting the thing. I screw the bridge down with 2 screws in the holes, and then I used stew macs slotting system. I got it cheap from some guy selling all his stuff a couple years ago. Maybe if I get time next week i'll set up a photo to show you. The box is almost ready for finish.ImageImageImageImage
Jason Moe
LaCrosse WI 54601
PostPosted: Mon Mar 25, 2013 7:43 am
First name: Tony
Last Name: C
City: Brooklyn
What is the bridge made of?
PMoMC
PostPosted: Mon Mar 25, 2013 1:13 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Hickory. Same as the fretboard and faceplate. I should bring it to work and weigh it.
Jason Moe
LaCrosse WI 54601
PostPosted: Mon Mar 25, 2013 1:27 pm
First name: Tony
Last Name: C
City: Brooklyn
I like it.
PMoMC
PostPosted: Mon Mar 25, 2013 10:48 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
So I just weighed 3 bridges.
1.Ebony-1.3 oz or 36.85 grams
2.IRW- 1.0 oz or 28.35 grams
3.Hickory 1.05oz or 29.76 grams.
The Hickory bridge does not have champhered holes. So that would add a touch of weight. Pretty much comparable to IRW weight.
Jason Moe
LaCrosse WI 54601
PostPosted: Tue Mar 26, 2013 1:48 pm
First name: Tony
Last Name: C
City: Brooklyn
You could taper the wings a bit more if you want to lose some more weight.
PMoMC
PostPosted: Tue Mar 26, 2013 2:23 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I like the light FB and bridge! Are you going to coat the FB with something to keep it looking clean?
Bryan Bear PMoMC
PostPosted: Fri Apr 12, 2013 12:57 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Nope, if I play it enough to get it dirty, so be it. I was thinking of selling it though. I'm setting up the neck angle and doing more sanding. I'm having a hard time getting rid of some burn marks in the waist.
Jason Moe
LaCrosse WI 54601
PostPosted: Mon Apr 15, 2013 1:18 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Glued bridge on, and added some maple to the heel of the neck. I had too much taper in the heel and some of the side showed. So I cut some of the neck heel off and glued on a wider piece.
Jason Moe
LaCrosse WI 54601
PostPosted: Mon Apr 15, 2013 9:40 am
First name: Tony
Last Name: C
City: Brooklyn
Is that a Fox bridge clamp? I use something similar and I love it. No clamps in the way to clean up the glue squeeze.
PMoMC
PostPosted: Thu Apr 25, 2013 9:09 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
So I started putting lacquer on. I love seeing how the color and curl pops when you first hit it.
Jason Moe
LaCrosse WI 54601
PostPosted: Fri Apr 26, 2013 2:15 pm
First name: Tony
Last Name: C
City: Brooklyn
Looks nice!
PMoMC
PostPosted: Sat Apr 27, 2013 1:19 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Thanks Tony. The curly ash I got from Jim Kirkwood. I got a couple more sets. This one was the most gnarley with knots and a few worm holes and this and that. Lots of weird figure. It bent like a dream. It's sad seeing all these ash trees around here being cut down due to the emerald ash borer beetle. Alot of wood is going to be wasted.
Jason Moe
LaCrosse WI 54601
PostPosted: Wed May 29, 2013 12:20 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Well after screwing around with the neck joint forever, and waiting for 3 weeks for my finish to come in. I got my finish done. I bolted the neck on tonight, and glued the fretboard down.
Jason Moe
LaCrosse WI 54601
PostPosted: Fri May 31, 2013 4:26 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Just because the challenge is over doesn't mean you don't have to post a video. Can't wait to see it!
Bryan Bear PMoMC
PostPosted: Fri May 31, 2013 10:28 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
+1 to that, Jason :)
