It is currently Fri Jun 12, 2026 1:26 pm
PostPosted: Wed Nov 06, 2013 1:29 am
Hi everyone,
This is my first post here, and I just finished making my first ukulele, so please forgive me if I don't have my terminology down, or am missing something obvious.
As I tuned my first ukulele, I found that each fret was slightly sharp. Each fret for the most part was sharp by about the same amount, according to my electric tuner. I'm not sure what I did to make it this way. I got my fret measurements from the StewMac website, and remeasured everything after all was said and done, and no fret is off by more than 0.5mm. The StewMac website said that nut and bridge height could cause things to happen, and my bridge may be slightly high. Other than that, I'm at a bit of a loss to explain why I'm off a bit on every fret, but since I'm off by roughly the same amount on each fret, maybe my ukulele is salvageable? I'd hate to have to scrap it!
Also, the thing won't stay in tune to save it's life. I leave it overnight, and all the strings are flat. Is this normal for a new instrument?
Thanks for your help, and please let me know if there's any other information I could provide that can help in my diagnostic.
PostPosted: Wed Nov 06, 2013 1:40 am
First name: duh
Last Name: Padma
check your intonation.
use better machine heads.
PostPosted: Wed Nov 06, 2013 3:09 am
City: chicagoland
State: illinois
bridge is probably too close to the nut
PostPosted: Wed Nov 06, 2013 11:00 am
First name: Sheri
City: Orange County
Zip/Postal Code: 92886
I can't offer too much help, but as far as the strings all being flat in the morning - the strings will continue to stretch for quite awhile. So what you report is not unusual.
PostPosted: Wed Nov 06, 2013 12:59 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Is it a Nylon string uke. Nylon strings take at lease 3 days before you should try to intonate. They take a bit longer before they stay in tune. ... Then you need to change them as they stretched too far and lost their tone. :D
These users thanked the author johnparchem for the post: sebastiaan56 (Fri Nov 15, 2013 9:30 pm)
PostPosted: Wed Nov 06, 2013 1:02 pm
:lol:
PostPosted: Wed Nov 06, 2013 1:28 pm
Did you build compensation into the scale?
Yes, it takes a few days for the strings to stabilize.
PostPosted: Wed Nov 06, 2013 1:53 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
You can help the tuning by pulling on the strings to make sure the knots are tight and the wraps around the tuning posts are set. But yeah....it takes a while for uke strings to settle
For the intonation; does it get sharper as you go up the neck? 12th fret is much more sharp than the 1st? That would be a compensation problem at the saddle. You'll probably have to move the bridge.
If its equally sharp everywhere, then you probably got the 1st fret too close to the nut. Or maybe the nut is loose and leaning forward some. You could try making a new nut that has the break point farther back. Or thin the nut and put a shim between the fret board end and the nut, keeping the shim below the strings.
PostPosted: Wed Nov 06, 2013 4:58 pm
City: winnipeg
State: manitoba
Country: canada
What Quine said.
What is the distance between the fret-top and the string bottom at the twelfth fret?
How much sharp is it?
bob :ugeek:
PostPosted: Tue Nov 12, 2013 6:02 pm
Online
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I was just about to say what Quine said. Check the spacing from the nut to first fret. Also make sure the action at the nut is not really high. If you capo the first fret, do all the other frets play in tune relative to the "open" notes on the first fret? If we can confirm that it is the nut location that is the problem, there a a few things you can do to fix it depending on how far off it is.
If it gets sharper up the neck then look to adding compensation to the saddle location but first get teh nut action and saddle height sorted out.
Bryan Bear PMoMC
