It is currently Sat May 16, 2026 12:47 am
PostPosted: Sun Mar 16, 2014 10:52 am
Some while back there was a thread/tutorial about making precise thin wedges. It may have been written by Todd Stock. I have looked for it in the Tutorials and other sections without success. Does anyone know where it is and can direct me to it?
Max
Max Bishop
Brighton, Michigan
PostPosted: Sun Mar 16, 2014 11:26 am
It was Todd Stock, and think it's been disappeared along with the rest of them and the writer.
I've just had the same problem with one the "tips" (and probably will have others) from Todd's posts.
I didn't save them on my computer originally because "I'll always be able to find them again". Little did I know.....
Maybe someone did save it, or at least can recall the method.
Something about double sided taping the material for the wedge to a block , and a known thickness of wood being used to prop up the back end of the hand plane being used the taper the wedge material, twice the distance from the end of the block as the end of the piece being tapered?
Imagine----
0.500" 0.25" 0.0"
I i (zero)
Rubbish representation, but maybe you'll get the idea.
Edit - woops! Sorry, spaces vanished when I submitted........
First name: Ringo
viewtopic.php?f=10137&t=39797
Unfortunately Todd's post is no more which is a shame
PostPosted: Sun Mar 16, 2014 11:41 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Todd has vanished ? :o
PostPosted: Sun Mar 16, 2014 11:46 am
First name: William
Last Name: Snyder
City: Brooklyn
I may be wrong but I think his tutorials are still on Youtube.
PostPosted: Sun Mar 16, 2014 11:50 am
First name: William
Last Name: Snyder
City: Brooklyn
...actually I think that one may not have been video in which case it's probably gone. You could try contacting him.
PostPosted: Sun Mar 16, 2014 1:31 pm
First name: Tom
Last Name: West
State: Nova Scotia
A sad, sad, day indeed...........!
Tom
PostPosted: Sun Mar 16, 2014 1:57 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
As Colin said if a block that is twice the desired height of the thickest part of the wedge is placed at twice the desired length of the wedge, using the block as a guide for behind the blade of a plane, when planing you will in up with the desired slope for your wedge.
A wedge follows a rise over run formula for the slope. For a wedge that tapers to zero -- Desired height / Desired length so (2 desired height) / (2 Desired length) gives you the same slope. Thus the placement of the guide block.
If you want a wedge that does not go down to zero then place the block of a height twice the difference of the thick end and the thin end twice the desired length away. Stop planing when the thin side is the correct height.
This is what I remember of Tod's tutorial.
These users thanked the author johnparchem for the post: Colin North (Sun Mar 16, 2014 2:20 pm)
PostPosted: Sun Mar 16, 2014 6:25 pm
Thanks, everybody. I think I have enough information to do what I want now.
Best wishes,
Max
Max Bishop
Brighton, Michigan
PostPosted: Mon Mar 17, 2014 5:35 am
I have a video shoot this weekend and we can do a video on this. Good topic
PostPosted: Mon Mar 17, 2014 6:55 am
Cool
Max Bishop
Brighton, Michigan
PostPosted: Mon Mar 24, 2014 5:47 am
John,
Will you post a link when the video is available?
Max
Max Bishop
Brighton, Michigan
PostPosted: Tue Mar 25, 2014 4:08 pm
One thing to think about here is that if the wedge you want to make (like I did last week for angling/shimming a reso neck) is longer than half the length of your plane sole, you need to adjust where the shim is, and its thickness.
ie .. I needed a 6 inch shim, that tapered to zero from about 120 thou ... so with the above mentioned formula, I made a riser that was 240, and placed it six inches away from the end of the shim stock .. took the first stroke with the plane and it fell off the 240 riser because there was a 6 inch gap between the shim and the riser .. so I had to make another riser, only 180, and place it 3 niches from the shim being planed .. then it worked out with the 14 inch sole jack plane I was using .... If you only have a block plane and are trying to make this shim .. good luck ...
Users browsing this forum: No registered users and 54 guests
