It is currently Wed May 06, 2026 2:46 pm
PostPosted: Thu Feb 19, 2015 8:33 pm
What's the skinny?
Must be able to cut curves, so some sort of 1/4" blade...
PostPosted: Thu Feb 19, 2015 9:37 pm
We have one saw equipped all the time with an Olson All Pro 1/4" 6 TPI. Always smooth running, stay sharp, breaks are extremely rare. We cut solid and laminated neck blanks on this saw.
Ken Cierp
PostPosted: Fri Feb 20, 2015 12:16 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Any bimetal 1/4" bandsaw blades such as Olson MVP or Lenox Diemaster will do well.
Typhoon Guitars
PostPosted: Fri Feb 20, 2015 7:02 am
First name: Jim
Last Name: Kirby
For a blade for regular use in the 1/4" range, I think the Viking blades from Lee Valley, or the Timberwolf brand, are just fine.
Jim Kirby
kirby@udel.edu
PostPosted: Fri Feb 20, 2015 9:45 am
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
Timberwolf brand works for me.
PostPosted: Fri Feb 20, 2015 10:38 am
+1 Timberwolf
Ken Jones
Mountain Song Guitars
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Fri Feb 20, 2015 11:06 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Plain (as in inexpensive) carbon steel 3tpi skip tooth unless you're cutting thin stuff under about 1/4". I like the skip tooth because I find it easiest to accurately follow curves - it goes where you push it & doesn't self feed. YMMV
Kevin Looker
I'm not a luthier.
PostPosted: Fri Feb 20, 2015 11:45 am
Timberwolf 1/4" 8 TPI RK. Cuts small stuff clean. Resawed a maple neck blank with it the other day and worked good, just slow.
PostPosted: Fri Feb 20, 2015 12:56 pm
Timber wolf isn't available at 125" unless I missed it...
PostPosted: Fri Feb 20, 2015 2:14 pm
The size I use is available 54" to 234" in 1/2" increments from Suffolk Machinery
http://timberwolfblades.com/index.php
PostPosted: Fri Feb 20, 2015 3:02 pm
Awesome, thanks!
PostPosted: Sat Feb 21, 2015 9:00 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
E- vil bay is where I get my narrow blades e.g. laguna for the 10in craftsman and 12 in BS, they track well. esp. for free hand work
PostPosted: Sat Feb 21, 2015 10:16 am
R & D Bandsaws (Tufftooth) in Toronto will weld to whatever your specs are, and you may save a bit with shipping being domestic.
Been using their blades for 5-6 years now and never any issues.
PostPosted: Sat Feb 21, 2015 11:57 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
My limited personal experience suggests to me that once we ditch the freebie POS that came on the bandsaw out of the box, anything with appropriate width/tpi will represent such a huge improvement that it's a can't lose propoisition if we buy a blade from a vendor who peddles namebrand professional saws, like Lenox, for one. They're all going to perform so well that the OP will be delighted no matter what brand he buys. Again, a personal opinion.
Peter Havriluk
PostPosted: Sat Feb 21, 2015 12:44 pm
Peter I tend to agree with you entry level BS blades are at best junk -- even Olson's. And I also agree that most all the name bands offer reasonably prices blades that will handle the every day tasks very well -- premise being the part time maker will save some $$ to spend on other fun stuff rather than buying the top of the line -- which again we can assume will offer most excellent performance but is it necessary for the tasks at hand? Now this logic (my logic) does not apply for blades intended for re-sawing -- for that I recommend the very best blade one can afford -- I've settled in on the "Wood Slicer" I've tried many including carbide tipped, I've found no peers.
Ken Cierp
PostPosted: Sat Feb 21, 2015 12:54 pm
Interesting.
I did buy a resaw king with my SUV. I want to get a wood slicer as well, just to see what it's about.
Something I find confusing is the options on TPI, rake angle and such. Day to day usage sees almost entirely extremely thin pieces, except once every guitar where it needs to chew 3" neck stock material..
Does the woodslicer come in1/4"?
PostPosted: Sat Feb 21, 2015 1:21 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
For the non- resaw blades I would just buy them from the local sharpening shop. These shops generally have rolls from lennox, olsen or morse and charge by the length. Cheap enough to have a few on hand.
Ed, in Vancouver Quality saw and knife sells BS blades this way. I also send these guys my better circular blades as they do the best job I have found.
PostPosted: Sat Feb 21, 2015 2:29 pm
I get my blades from them presently. I didn't think to ask for better quality. They are the peeps who turfed my fretsaw blade...
PostPosted: Sat Feb 21, 2015 3:06 pm
Wood slicer only comes in 1/2 and 3/4. It does make extremely nice and super thin cuts. I think I was getting something like .045 kerf. Does NOT last long and exotics though.
PostPosted: Sat Feb 21, 2015 3:27 pm
That's what I've read as well. Apparently the resaw king is better that way...
PostPosted: Sat Feb 21, 2015 3:33 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I think woodslicer is designed for applications where the wood is extremely expensive and you want the maximum yield, regardless of how many blades it take to saw it.
It doesn't really do curves at all since it has no set, so it's bad for curves. Maybe it can be easily resharpened.
Typhoon Guitars
PostPosted: Sun Feb 22, 2015 12:47 pm
+1 for R&D bandsaws in Brampton Ontario .. only blades that have been on myh saw since day one ... I only really use 2or 3 blades .. 1/2 3 tpi for resaw, 1/8 - 10? for fine stuff, and sometimes a 3/16 8 or similar, I couldn't seem to get a 1/4 6 to run smooth, might have been a bad blade, but all the others I from there I have ever tried have been great .. going to get some more this weekend at the Hamilton wood show ...
