It is currently Thu Jul 24, 2025 10:32 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 06, 2015 2:08 pm
Thanks for the additional info, Bryan!
PostPosted: Wed May 06, 2015 2:22 pm
Quote:
I did a bolt down tongue for a while but found they shifted forward rapidly. I think the shear strength of a glued extension helps a lot.
Really? The extension end moves toward the sound hole? What does this look like and how does it or how can that happen? Guess I am not clear because I don't even glue or fasten the extension and "never" seen the relationship/distance between the sound hole edge and the extension change.
Ken Cierp
PostPosted: Wed May 06, 2015 2:37 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
TimAllen wrote:
. . .I use hanger bolts in my guitars, hangar bolts in my airplane sheds. :D
Ha! I've been spelling it wrong all this thyme! laughing6-hehe
Bryan Bear PMoMC
PostPosted: Wed May 06, 2015 2:42 pm
First name: Greg
Last Name: B
City: Los Angeles
My current fave neck joint is: Butt joint, walnut dowel through the heel (glued with HHG), brass inserts glued in with CA, furniture fasteners.
Has anyone else noticed how much gluing in a dowel changes the sound and apparent sound transmission of the neck? I know that may sound unbelievable, but try it. It's not subtle. It might be different if using PVA and soft mystery wood dowels.
PostPosted: Wed May 06, 2015 2:46 pm
Bryan Bear wrote:
James Orr wrote:
Thanks, Bryan. I'm all about increased simplicity! I'll probably err on the cautious side on the first go-round though.
James, I just saw your earlier question and realized that I still left a bit of info out of my answer. I have not yet done the machine screw into the hardwood dowel but I have been doing bolt on butt joints without inserts using hangar bolts. By design, the wood threaded end of the hangar bolt wold be expected to hold in the heel (just as the wood treads of the insert would) but I was postulating that the hardwood dowel could also be tapped with machine threads and that those threads (in wood) would also be up to the task with the forces involved. As I see it, the only advantages the threaded inserts have over the hangar bolts is that it is slightly easier to floss the heel since the bolts can be taken out of the way. The advantage to the hangar bolt is the smaller intrusion into the wood of the heel allowing for a slightly slimmer heel. Tapping machine threads into the heel would seem to have the benefits of both and the added bonus of only having to by one piece of hardware.
I don't use hangar bolts but I seem to remember that they have a slot head in the machine screw side and that would make it possible to remove through the sound hole with a flat head driver?
For any of you that use the dowel method do you have a video or pictorial tutorial on that?
PostPosted: Wed May 06, 2015 2:57 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'd like to hear more about this. I have never noticed because I have never added the dowel to a neck that already existed so I don't know what it sounded like before. Can you describe the difference? How guitars have you done this to?
Bryan Bear PMoMC
PostPosted: Wed May 06, 2015 3:28 pm
First name: Greg
Last Name: B
City: Los Angeles
Seems to increase sound transmission. IE, if you tap or put a tuning fork at the 1st fret area, it can be heard more clearly at the heel end. Also, the whole neck gets louder WRT ring/tap tone. The last guitar I made with that kind of neck/dowel has very consistent sound up the neck, and somewhat excessive finger noise. (might be partially due to black walnut for neck material)
I didn't do it to a complete neck. They were 90% carved and had no fretboards when dowels installed. I tap on things a lot when building.
Well, two so far, so not exactly a scientifically meaningful sample size! I wouldn't have mentioned it, except that the effect is fairly dramatic and obvious.
PostPosted: Wed May 06, 2015 5:56 pm
This seems to fit into the discussion --- Older Taylor's
http://www.frets.com/FretsPages/Luthier ... reset.html
Ken Cierp
These users thanked the author kencierp for the post: Bryan Bear (Wed May 06, 2015 10:23 pm)
PostPosted: Wed May 06, 2015 6:16 pm
meddlingfool wrote:
Aluminum and brass.
I love the look. Was it difficult to get them level with the fretboard binding? Whenever I think about doing this, I worry that the dot and binding will sand unevenly.
If it was hard, I wouldn't do it...;)
Ken, that's exactly what I did and why I like it.
PostPosted: Wed May 06, 2015 7:29 pm
I can see it now... Dowels glued into dove tails for superior tone :)
I kid. I've never tried it so I don't know but forgive me for having strong reservations about that.
Having said that, but for my case mostly for marketing purposes, like the Frets.com link that Ken put up you can see that Taylor routed out the heal such that it's convex and only touches along the very edge of the contact with the sides. IOW the center is hollowed out. I built a guitar for a very good classical player who was very concerned about the bolt on joint VS the traditional Spanish joint. I convinced him that there is full heal to body contact just like a Spanish joint perfectly flush. It made him happy. And who knows it may have better tone because of it. But I doubt it. [uncle]
PostPosted: Wed May 06, 2015 8:14 pm
I have been using the double tenon Bourgeois joint as described by John Mayes and Sylvan Wells for 9 years. Before that a bolt-on neck with a glued extension. They DO move more. I think the reason is that there is almost no top glued to the headbock with the large Bourgeois style mortise the the headblock can rotate more easily.
My guitars would go out looking great but when I saw them back at a year or so the action had frequently come up a 32nd or so due to a small change in the neck angle from what I think is headblock rotation because of lack of support in sheer. A minor neck re-set which goes quickly fixed it and they were stable after that. I didn't like it. I had not seen that with a glued extension.
I discussed this with Sylvan who had seen the same thing especially in cutaways. I found that Dana leaves a gap between the top brace and the fretboard mortise when the top is glued on and afterwards wedges in a filler strip to push on the headblock. His top brace has beefier ends and they have extra support.
I did this plus making the mortise smaller to allow more top to be glued to the headblock as well as reinforcing the mortise block edges for more rigidity and adding a 60' radius to the upper bout which I used to leave flat.
I have been doing this a couple of years and it has made a big difference. I still think they may settle a little more than a glued extension but it's a lot better. I don't consider it totally solved but am trying to avoid internal struts etc if possible.
Here's the newer mortise. After I cut it the gap is exposed between the mortise block and the top brace and I can wedge in a filler strip tightly and run in some thin CA.
Here is the fretboard tenon.
And the reinforcing of the edges of the mortise block.
One thing I have seen in a guitar that was over humidified with both a high output Oasis in the sound hole and two case humidifiers was slight warping of the end of the fretboard which is largely unsupported. I would worry a little about that in a guitar that simply has an unsupported extension lying on the top with out being glued.
PostPosted: Wed May 06, 2015 11:24 pm
Terrence, I found the exact same thing. Though I don't personally feel it has much to do with how much surface the head block has. If anything,,there is more surface glued with the paddle that supports the fingerboard.
I think it comes down to shear strength.
In any case, I was finding brand new expensive guitars were out of whack very quickly. No biggie if addressed, a ten minute fix, but, I was finding clients simply didn't see it. They perceived a loss of enjoyment without having an idea as to why. And, as they were starting to go far and wide, this was unacceptable to me.
So I went back to glueing the tongue. Easy peasy.
I had planned on experimenting with an adjustable set screw going through the UTB into a brass cap in the fingerboard tenon, and then I had this brilliant idea, which was to say 'meh'.
PostPosted: Thu May 07, 2015 8:05 am
Yeah, I've thought about going back to a glued extension a few times but I think I am on to something now and they seem quite stable. Actually if you rout the big Bourgeois/Mayes style mortise in the headbock and headbock extension you remove much of the wood of the extension and I found it to weaken it significantly. You could make it thicker but then there is not enough room for the top bolt. The top is only glued to a small edge of the headblock and extension after that big mortise is routed. Even less in cutaways.
We'll see--- The ones I have done with the mods are not local and I have to track them down but talking to the owners they say things are holding fine. I did find the same thing you did. I'd see one back earlier and the owner would say he loved it. I'd see that the neck had moved a little and fix it and there would be this amazed look on their face and they would say something like "My God it plays so much better".
I may well be back here in a year gluing the extension. :)
PostPosted: Thu May 07, 2015 12:20 pm
Terence and Ed, I have also been using the double bolt on tenon on my guitars. I have not experienced the movement that you have. I do some small differences, I make the headblock and paddle as one piece and fit it tightly to the UTB and glue, and I support the other side of the UTB with beefier soundhole braces...this transfers any tendency to rotate to the sides via the main X.
I kept one OM for my self, almost 4 years old and no movement.
Here is a pic of my headblock again, the only downside is the 5/8" of end grain that the side is glued to which could be eliminated by fitting the paddle into a rabbet...
Chuck
PostPosted: Thu May 07, 2015 3:33 pm
First name: Greg
Last Name: B
City: Los Angeles
No worries. I respect your skepticism, and usually have a similar view on such matters also. I am more than skeptical of the electric guitar tone obsessed dudes and their irrational ideas. For example, the idea that if a neck isn't so tight it needs to be hammered into its slot with a mallet, the guitar won't have any magic mojo...
Anyhow, not saying that it's good or bad, just interesting that gluing in a walnut dowel made noticeable changes. I'll try a brazilian rosewood dowel next time, for extra magic... ;)
These users thanked the author Greg B for the post: jfmckenna (Fri May 08, 2015 9:10 am)
PostPosted: Thu May 07, 2015 5:49 pm
Chuck
Thanks Chuck. I always used a separate mortise piece tightly butted against the headblock and wedged against the top brace. I just recently started beefing up the soundhole bracing. Your mortise extension is definitely thicker than mine too.
Food for thought.
Thanks again
Terry
PostPosted: Thu May 07, 2015 6:36 pm
First name: Trevor
Last Name: Gore
City: Sydney
I've not had any problems with this style of double tenon.
http://www.goreguitars.com.au
PostPosted: Thu May 07, 2015 7:57 pm
I think the mahogany insert that extends into the neck really helps with that, as it eliminates the 'hinge' effect. I'll likely use that on future deluxe guitars, but it's too much work for our budget boxes.
PostPosted: Fri May 08, 2015 8:01 am
I really like that fully supported fretboard as well Trevor. I assume the upper bout angle has to be perfectly co-planar with the planned neck angle and if you wanted drop off you'd have to sand it into the fretboard
I do have your book but don't recall seeing how much movement you get with string tension i.e. how much gap you shoot for over the bridge unstrung with your system.
Ed I have definitely seen a "hinge" effect at the neck body joint with the separate tenon and have made my upper bout angle a little less than the ideal neck angle to compensate for that. Lots of variables to juggle.
Lots of good ideas here.
Terry
Last edited by Terence Kennedy on Fri May 08, 2015 10:02 am, edited 1 time in total.
PostPosted: Fri May 08, 2015 8:12 am
Check out McPherson
http://mcphersonguitars.com/technology/
Ken Cierp
PostPosted: Fri May 08, 2015 8:22 am
Trevor's dual tenon certainly is doable for the small shop. Even with CNC equipment Taylor's profile heel pocket design is a challenge (I have experimented) the neck heel itself was troublesome for me, you take it a fraction too small and its scrap.
Ken Cierp
PostPosted: Fri May 08, 2015 8:39 pm
First name: Trevor
Last Name: Gore
City: Sydney
Section 4.6.12 in Design, "Neck angle, neck relief and top curvature". Few texts do a good job on this subject. I don't know another that discusses the interrelation between relief and neck angle, for example.
These users thanked the author Trevor Gore for the post: Terence Kennedy (Fri May 08, 2015 8:56 pm)
PostPosted: Mon May 11, 2015 8:51 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Trev, thats why they don/t discuss it, very tricky to get it right.
Users browsing this forum: Chris Ide and 33 guests
