It is currently Sat May 23, 2026 2:40 pm
 Post subject: Simple SS Fret tang jig
PostPosted: Thu Jun 23, 2016 1:00 pm
Last Name: Colbert
City: Anacortes
Hi all,
Here is a jig I came up with for cutting SS Fret tangs on bound boards. It uses a SM Dremel adjustable base and a 1-1/4" Dremel cutoff wheel so you get easy fine adjustment and a quick cut. The only downside is the fret gets a bit warm during the cut so I keep a little cup of water on hand to cool it down afterward. It never gets so hot that it discolors the metal but certainly too warm to touch. Works like a champ!
Cheers, M
These users thanked the author Michaeldc for the post: DannyV (Fri Jun 24, 2016 11:11 am)
PostPosted: Thu Jun 23, 2016 1:10 pm
Clever. I like it. Could be adapted to work other than fret trimming, too.
PostPosted: Thu Jun 23, 2016 1:38 pm
Last Name: Farmer
City: Durango
State: CO
Switching to a small jewelers saw blade would cool things down. Just a thought.
PostPosted: Thu Jun 23, 2016 3:14 pm
That's a good idea!
Neat! I likes that.
These users thanked the author Colin North for the post: Doug Balzer (Sat Jun 25, 2016 6:43 pm)
PostPosted: Thu Jun 23, 2016 3:24 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
How come all my jigs look like they were assembled by drunken elves?
These users thanked the author JSDenvir for the post: Imbler (Thu Jun 23, 2016 6:14 pm)
PostPosted: Thu Jun 23, 2016 3:41 pm
Have you been drinking?
PostPosted: Thu Jun 23, 2016 3:51 pm
Last Name: Colbert
City: Anacortes
Because I cheat and use my CNC to make my jigs...
PostPosted: Thu Jun 23, 2016 5:03 pm
Last Name: Farmer
City: Durango
State: CO
Only a matter of time before every drunken elf has CNC.
PostPosted: Thu Jun 23, 2016 5:14 pm
Very nice!
PostPosted: Thu Jun 23, 2016 5:32 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
Great set up. That's exactly what I will need on my current build. Since I don't have a CNC set up, I can use the rosette cutter jig on my Stewmac plunge base to cut the wheel base most of the way. What do you think about a small fence on one side to control fret as you you push it into the wheel? Thanks.
Brad Hall
Mystic Dawg Guitars
PostPosted: Thu Jun 23, 2016 5:36 pm
First name: Fred
City: Winnipeg
If only you can get them to load the parts right side up.
These users thanked the author printer2 for the post: david farmer (Thu Jun 23, 2016 5:42 pm)
PostPosted: Thu Jun 23, 2016 5:45 pm
Last Name: Colbert
City: Anacortes
Brad,
If I'm understanding you, I think the 1/32" wide slot guide is a better way to go than a fence because the fret body is held co-planer with the cutoff wheel. Does that make sense?
Best, M
PostPosted: Thu Jun 23, 2016 5:48 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Is there a slot on your set up? I can't see it in the photo. You're right, a slot would be much better. Thanks.
Brad Hall
Mystic Dawg Guitars
PostPosted: Thu Jun 23, 2016 6:05 pm
Last Name: Colbert
City: Anacortes
Yup, look closely at the first photo.
PostPosted: Thu Jun 23, 2016 6:07 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Duh..don't know how I missed the first photo. Thanks again.
Brad Hall
Mystic Dawg Guitars
PostPosted: Thu Jun 23, 2016 6:15 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Or on a slightly more relevant note: Have your elves been drinking? :)
PostPosted: Fri Jun 24, 2016 10:21 am
Last Name: Denvir
City: Baltimore
State: ON
Well geez, now that you mention it... :-)
Users browsing this forum: No registered users and 67 guests
