It is currently Wed Apr 29, 2026 7:09 am
 Post subject: Plastic Template making
PostPosted: Fri Nov 18, 2016 2:42 pm
City: Alton
State: IL
I've been using MDF for all of my templates. Lately I've been thinking about moving them to something more permanent. I think the thick arylic that StewMac uses for their body cavity templates. But I'm not sure if that would be good for me to make, since they are laser cut.
So what's a good solution given this criteria:
1.) Clear plastic, so I can see the piece beneath
2.) Workable with woodworking tools, or workable without the need of specialty tools
3.) Readily available in sizes for guitar templates in low quantities.
What has everyone found that has worked for them?
PostPosted: Fri Nov 18, 2016 5:05 pm
Lexan I hope!
PostPosted: Fri Nov 18, 2016 9:00 pm
First name: Rob
Last Name: Lak
State: Massachusetts
I am in the process making lexan templates and the tips here (viewtopic.php?f=10101&t=48547) are great!.
lexan is a bit pricey, but you can get small sheets (18 x 24 @ 3/32" or 0.93) for about $20 at home depot. I'm hoping it's thick enough...
I bought a cheap awl for $6 at the local hardware store to do the tracing.The marker is staying OK, but i wish it were darker.
Here's what it's looking like.
The area where there is no text is a plain sheet of paper inserted under tthe lexan and on top of the plan to show that the lines are coming out decent...
i'll probably just use stickers for the detail text.
PostPosted: Sat Nov 19, 2016 8:06 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
The .090" polycarbonate material we use has proven to be very durable and relatively inexpensive - it can be bent double without shattering (please do not try this with acrylic!), and even after multiple trips to the concrete shop floor and being tossed around lumber yards during wood scouting trips, the templates work well and show no unusual wear. For body templates to be used for routing, we use 12mm/1/2" MDF and use a separate .090" polycarbonate template for layout to minimize parallax error.
These users thanked the author Woodie G for the post: Evilfrog (Sat Nov 19, 2016 12:48 pm)
PostPosted: Sun Nov 20, 2016 5:46 pm
You can find plexi and polycarbonate scrap for sale on ebay
PostPosted: Sun Nov 20, 2016 6:55 pm
Last Name: Colbert
City: Anacortes
If you're using acrylic, you want to use cast, not extruded. The cast has a higher melting temp. +1 for sourcing on eBay.
PostPosted: Mon Nov 21, 2016 1:10 am
Last Name: Beaver
City: Lake Forest
I like the polycarbonate from Home Depot. It might be branded Lexan, I'm not sure. They also sell cheaper acrylic. it is ok but does crack easier.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Nov 21, 2016 11:48 am
OLF Sponsor
OLF Sponsor
First name: Brent
Last Name: Cole Sr
City: Craig
State: Alaska
Zip/Postal Code: 99921
Country: USofA
Lexan is very expensive, and plexiglass is too brittle. I contacted a plastics shop, San Diego Plastics and they sold me the right stuff at a great price. I don't remember the name of it. But any plastic shop should be able to tell you and have it in stock. The 1/8" thick sheet is perfect.
These users thanked the author Alaska Splty Woods for the post: Colin North (Mon Nov 21, 2016 7:30 pm)
Users browsing this forum: No registered users and 371 guests
