It is currently Wed Apr 29, 2026 6:44 am
PostPosted: Sat Nov 19, 2016 3:09 pm
State: PA
This is my 1st attempt at a 12-string. Here are some specs & pictures:
Back & sides: Australian Blackwood (RC Tonewoods)
Top: Engelmann Spruce (433 kg/m^3 density)
Neck: Honduran Mahogany
Bindings, Head Plate & Back Strap: Curly Koa
Tuners: Antique Acoustics (pricey) (Elderley)
Bridge: EIR
Saddle: Bone, with individual string compensation
Finish: French polish (CA pore fill)
Top thickness procedure: Starting with known top density, I used some of Al Carruth's data & ideas to calculate what top thickness I would use if this were a 6-string guitar (0.107"). I then used D'Addario data to obtain the string tensions for a 6-string (EFT16; 171.5 lb) & a 12-string (EJ38; 252.1 lb) setup. The cubed-root rule was then applied:
Thk-12 = Thk-6*(Tension-12/Tension-6)^0.333, or
Thk-12 = 0.107"*(252.1/171.5)^0.333 = 0.120".
I used an extra large heel block with an A-frame upper bout bracing (see pic). I also used extra bulky side braces to help keep the sides rigid & to add some mass to the sides.
It sounds great! (And is loud.)
PostPosted: Sat Nov 19, 2016 4:14 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Wow! very nicely done. Nice design, also I love the look of the Australian blackwood
PostPosted: Sat Nov 19, 2016 4:45 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Very nice! How big is it? How wide is the lower bout? It looks like a lot of work went into the saddle.
Regarding the A-frame braces, were they actually let in to the heel block, or were they butted to the heel block?
PostPosted: Sat Nov 19, 2016 4:53 pm
Nizzze!
PostPosted: Sat Nov 19, 2016 5:37 pm
Online
City: Tyler
Incredible!
PostPosted: Sat Nov 19, 2016 10:03 pm
First name: Freeman
Last Name: Keller
Beautiful guitar, Steve. How do you like the smaller body? Are you tuning to concert? Any significant changes to bracing in the lower bout?
Fwiw, when I built my OM 12 I just followed Taylors lead and bumped the top thickness from my usual 0.110 to 0.125 (but I also tune down). My old Martin 12 is 0.115 and has developed a bit of a belly.
PostPosted: Sat Nov 19, 2016 10:43 pm
Very nice!
PostPosted: Sun Nov 20, 2016 5:39 am
It looks great. I have a nice set of blackwood and seeing yours makes me want to build with it.
PostPosted: Sun Nov 20, 2016 11:19 am
Wow! That's beautiful!
PostPosted: Sun Nov 20, 2016 1:40 pm
A touch of class there Steve. EIR FB too?
What's the scale length?
Be nice to see one pic of the whole guitar
PostPosted: Sun Nov 20, 2016 2:59 pm
State: PA
Thanks for the kind words & interest!
Answers to questions:
J De Rocher
The overall length is ~41" with a lower-bout width of 15".
The A-frame braces are glued into ~1.5" long channels in the heel block.
I used Liutaio Mottola's "Fretted Bridge Saddle Compensation Calculator" http://www.liutaiomottola.com/formulae/compensation.htm
to do the saddle compensation. Mottolo's calculator is set up to deal with 12-strings (or any number). Worked well & was easier than using the approach of putting a wire under each string & adjusting to set string length.
Freeman
The guitar is tuned to concert pitch, but I am using extra-light strings right now.
The lower-bout bracing was also beefed up a bit. The X-brace is 0.35" wide, 0.65" high, triangular profile, no scalloping.
The fretboard is ebony. I thought of using same materials for FB & bridge (either ebony or EIR), but I liked the look my classicals that use ebony FB with EIR bridge.
Scale length is a short scale 24.9"
PostPosted: Mon Nov 21, 2016 11:19 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Nothing more impressive that a big slot-head 12string head stock
PostPosted: Mon Nov 21, 2016 3:51 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
very well made & beeeeeaaaauuuutiful also! [:Y:]
Mike Collins
PostPosted: Mon Nov 21, 2016 4:20 pm
First name: Jay
City: Bothell
State: Washington
That's an interesting idea. I haven't seen that before, but like a lot of things, maybe it's have been done at some point in the past. I imagine it adds a significant amount of strength to that area. How do you make the channels?
PostPosted: Mon Nov 21, 2016 4:54 pm
Great miters on the end graft. What's your technique?
Beautiful instrument, not something you see everyday.
PostPosted: Mon Nov 21, 2016 7:40 pm
State: PA
The A-frame is not an original idea with me. I learned about here on the OLF. The following link has some discussion & a nice pic from Buton LeGeyt.
viewtopic.php?f=10101&t=45037&hilit=carruth+a+frame&start=25
Thanks for noticing. Until this guitar, I had never been able to get all 4 miters on my end grafts, usually getting 3 acceptable ones & one that I was not proud of. Cutting the purflings attached to the bindings has never been a problem. Just used a small (~1.5 mm) chisel with a mirror-polished back. For the purflings on the end graft proper, I never had complete control of cutting miters using a chisel and the polished-mirror trick. (The purflings are glued to the end graft & installed as a unit.) For this guitar (oh, the shame of not using an edge tool :oops: ), I used my disc sander with a 45-deg fence & my binocular magnifier visor to see close up: Perfect control to get the miter at 45-deg & no wandering through the depth. Getting a perfectly vertical cut with a chisel was always a problem. Guess I should have built a jig. I recently saw that Stew-Mac has a drill press mounted binding cutter that might solve that problem.
These users thanked the author SteveT for the post (total 2): Terence Kennedy (Tue Nov 22, 2016 12:02 am) • J De Rocher (Mon Nov 21, 2016 8:38 pm)
Users browsing this forum: No registered users and 676 guests
