It is currently Fri Sep 19, 2025 8:58 pm
PostPosted: Sun Mar 05, 2017 9:17 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I have a client who has written to me about refinishing the top of a LaPatrie classical guitar (made by Godin, Quebec). All I know about the original finish is what they put in their advertising:
"LaPatrie guitars also feature a Custom Polished finish, which is reminiscent of the French polish of the 19th Century. This Custom Polished Finish, as opposed to "thick" polyester finishes, allows the top not only to be protected but also to breathe and vibrate freely" Elsewhere, they use the term "lacquer".
So, apparently not shellac and not a polyester. I'm suspecting not nitro, given the long cure requirement, so perhaps a water-based varnish?
Any of the repair or finish gurus here know what this might be and what might be an appropriate refinish option or approach. If I find a spot of acetone under a tuner plate burns in, do I dare use nitro (my regular finish)?
If i can do a good job at a reasonable price, I'd take the job on, but not if I'm likely to open a can of worms. I doubt the guitar is worth more than $1500, but I don't yet know the exact model.
PostPosted: Mon Mar 06, 2017 8:28 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Sounds like a post cat poly to me. I apply quite a bit of Conversion Varnish on classicals and flamencos and it fits the description. I would not base what the top is finished in by what is on the body.....it is not unusual to find a thicker more traditional finish on the neck and body and something different on the top.Being a factory made good I doubt it was a water based finish from the factory
Brian
PostPosted: Mon Mar 06, 2017 11:28 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Very helpful, Brian -- your info on finishing is ALWAYS helpful.
So, if it were Conversion Varnish or otherwise a mystery finish, would there be a safe way to apply a nitro finish (since that's what I'm set up for)? Surface prep? Sealer type?
Or should I just turn the job down? Doesn't really bother me to say "no", but also doesn't help the client.
PostPosted: Tue Mar 07, 2017 8:01 am
Last Name: Howard
City: Magnolia
State: Delaware
Lacquer should stick just fine. I would only run a sealer if there is bare wood otherwise scuff the existing at 320 and shoot a regular course of nitro and buff as usual.
Brian
These users thanked the author B. Howard for the post: Tim Mullin (Wed Mar 08, 2017 7:01 pm)
PostPosted: Tue Mar 07, 2017 10:20 am
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
French polish would do no harm, will stick to almost anything and is a traditionnal finish for classical.
These users thanked the author Alain Lambert for the post: Tim Mullin (Wed Mar 08, 2017 7:01 pm)
