It is currently Wed Jul 30, 2025 1:24 am
PostPosted: Sun Mar 19, 2017 4:22 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
1999 model, I think I was told. U can use serial to look it up. All 5 back braces are loose. Top cross brace loose, both top longitudinal braces seem ok. Getting a scope in those later. But as you can see from pictures, area behind bridge is bulging up. Area in front of bridge is sunken. Bass does not have much volume. What are your recommendations for repair?
PostPosted: Sun Mar 19, 2017 4:25 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Oh, and that pickguard has bubbles under it. What about that?
Look at the saddle. Looks really loose in slot and tilted forward. Is this correct?
Notes: All bracing is not buried in the kerfed lining (no wonders it pops off?)
PostPosted: Sun Mar 19, 2017 5:35 pm
They pretty much all do that. They sounded pretty good for a flat top bass while they lasted, but they implode rather consistently and predictably. A few years after that one was made they redesigned the bracing because they saw all these basses collapsing, and the later design is more stable, but sounds about as mediocre as any other flat top bass.
I've repaired a few of these, mostly just to keep them hobbling along for as long as they may last, but I don't believe there's any great solution without adding additional bracing (which I've done), which changes the tone.
PostPosted: Sun Mar 19, 2017 6:18 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
David, did you remove top? (to add bracing)
All bottom braces are loose
I know that is a crazy idea. But a new top with original bracing will give it its voice back for a few more years.
PostPosted: Sun Mar 19, 2017 7:01 pm
I can't imagine doing anything so drastic, simply by a cost/value consideration. When I've added braces, it's all been worked through the soundhole and preamp hole in the side. Removal of the back or soundboard would push the cost above the value.
These users thanked the author David Collins for the post: Patrick Nelson (Mon Mar 20, 2017 10:07 am)
PostPosted: Sun Mar 19, 2017 7:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Yeah. I think that makes sense. Guy who owns it got for $700, well below average book. He says he will be last owner. He can afford it. But if it can get close to normal with rehydration and reglue, that's best.
What about that tilted saddle? Not even close to vertical
PostPosted: Sun Mar 19, 2017 8:59 pm
I do recall having to do something with a similar saddle iss on one of these recently (last few years anyway). Can't recall if I plugged and refute the slot, or just cut it a bit wider and deeper. I do recall one of these having a very warped and distorted slot though which we had to deal with. Must be another typical issue with these.
PostPosted: Sun Mar 19, 2017 9:19 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Here are some saddle pics
Last Name: O'Melia
City: Huntsville
State: Alabama
That just looks like a tilted, Ill fitted saddle to me
PostPosted: Sun Mar 19, 2017 10:15 pm
Yeah, could be. The case I recall dealing with had a saddle so warpednand a bridge so weak and unsupported in front, that the slot itself had warped so much as to be unusable.
PostPosted: Mon Mar 20, 2017 1:09 pm
Last Name: Beaver
City: Lake Forest
I wonder what a Thunderchief would be like if the same bracing patteren was used but using carbon fiber in the braces?
Joe Beaver
Maker of Sawdust
PostPosted: Mon Mar 20, 2017 1:35 pm
If memory serves that is a "bindingless" model if that is the case I would not hesitate to pull the back and "easily" perform repairs and or mods.
$.02
Ken Cierp
PostPosted: Mon Mar 20, 2017 4:03 pm
Rather than over bracing it, I wonder how nylon cored harp guitar strings would make it sound.
PostPosted: Mon Mar 20, 2017 6:41 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I really want to yank the top. No binding there as well. And top is wrecked. Bulging. Sinking. Easier to match a new top.
PostPosted: Mon Mar 20, 2017 6:42 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
If I did this, I'd replace bottom braces and tuck them. Can't believe they are not tucked.
PostPosted: Wed Mar 22, 2017 10:22 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Lots of talking back and forth with owner. Still haven't heard anyone say "oh hell no! Do not remove top!" I'm guessing that's the nature of this relatively inexpensive instrument. It's not a Gibson or Martin, nor is it a six string. Can't help noticing the top is basically failed. Owner does not plan to sell, got it relatively cheap $700. Would I destroy this instrument if I rebuilt the top? Light carbon laminated bracing?
PostPosted: Sat Mar 25, 2017 3:38 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
If I do this, my plan is to recreate top exactly. Bracing too. But, I want to use carbon fiber in the bracing. Where do I buy this carbon fiber? And is it best to epoxy the wood and fiber?
PostPosted: Sun Mar 26, 2017 2:51 pm
Last Name: Beaver
City: Lake Forest
Mike,
I get my CF here, from the recommendation of Mario Proulx . https://store.acpsales.com/products/236 ... nal-sheets
( ACP Composites, CL3-37)
It really helps stabilize the top during RF changes. Since yours is more a matter of being under braced you may consider .030 or doubling .022.
I use the .022 thickness and epoxy to join.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Apr 01, 2017 12:20 pm
Might be a good candidate for a Bridge Doctor.
