It is currently Fri Apr 24, 2026 5:01 am
 Post subject: Surface Protection
PostPosted: Sun Jan 13, 2019 5:10 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I am always looking for a good way to protect surfaces when I want some finish or pore fill to not touch. I have been thinking about this for a while. Normally its blue tape and paper. I finally stepped out and bought a simple product called carpet protector film. You know, the slightly sticky stuff they put on carpets when selling a new house. I applied it to the top of the guitar, did all of my epoxy work, then removed. Use a hair dryer. Not because it will lift grain (it did not), but because you will need to if you want it off in a short period of time. Perfectly sealed against epoxy intrusion.
These users thanked the author Mike OMelia for the post: Terence Kennedy (Sun Jan 13, 2019 5:44 pm)
 Post subject: Re: Surface Protection
PostPosted: Sun Jan 13, 2019 6:12 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
It should be noted that this solution is NOT a good idea if you are using a solvent based product. Nitro, etc. Its only for water borne, and epoxy stuff.
These users thanked the author Mike OMelia for the post (total 2): Cal Maier (Mon Jan 14, 2019 9:35 am) • Durero (Sun Jan 13, 2019 8:48 pm)
PostPosted: Sun Jan 13, 2019 10:21 pm
First name: Trevor
Last Name: Gore
City: Sydney
Mike,
Would that stuff seal a fretboard with frets in, epoxy filling up to the fretboard surface?
TIA.
http://www.goreguitars.com.au
PostPosted: Mon Jan 14, 2019 9:37 am
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Hi Mike, where did you find this product?
Thanks.
PostPosted: Mon Jan 14, 2019 11:30 am
First name: Larry
Last Name: Hawes
Perhaps ??
https://www.homedepot.com/p/Surface-Shi ... /205187255
Thank You and Best To All
These users thanked the author LarryH for the post: Cal Maier (Tue Jan 15, 2019 10:18 pm)
PostPosted: Mon Jan 14, 2019 1:10 pm
Last Name: Beaver
City: Lake Forest
I know that HomeDepot and Lowes carry it.
During my short career as a home builder I used it to make a pathway across carpeted areas when I was expecting tradesmen. It worked well for that as long as you didn't leave it on to long, as in weeks.
I wished I'd thought of it as a guitar maker.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Jan 14, 2019 1:23 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
What happened if you left it on for weeks?
I wonder if this leaves any unseen residue that might interfere with finishing. I had some non slip mat stuff that left a pattern on the wood once you started finishing, very annoying.
Bryan Bear PMoMC
PostPosted: Mon Jan 14, 2019 1:48 pm
Last Name: Beaver
City: Lake Forest
Bryan, left it on at the owners request. Waited several weeks for the closing then they moved in. Called shortly after and complained the film was hard to get off the carpet. I told them to just man-up..... well, actually I wanted to but in reality I spent the better part of an afternoon pulling pieces off the carpet. Turns out the plastic film got weaker (foot traffic?) while the glue seemed to get stronger.
Regarding your concerns about it leaving a film after it has sat on the wood awhile, I would be concerned also if it was an area that latter would have a finish applied. I would be interested in using it on the fingerboard as Trevor eluded to and the top. For the top I think I would seal it first with Vinyl Sealer, (not a fan of shellac). Then you could wipe the top with a solvent before the finish went on. Just an idle thought
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Bryan Bear (Mon Jan 14, 2019 1:56 pm)
PostPosted: Tue Jan 15, 2019 5:57 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I think it would work great for fret boards. Yes, u should clean surface. Just like you would after using tape. Maybe more so. I did seal the top. I did rub it down with mineral spirits when I was done. Yes, that’s the product linked to above. There is another meant for hard surfaces I felt would not work. I would not leave it on the top for more than a few days.
These users thanked the author Mike OMelia for the post: Trevor Gore (Tue Jan 15, 2019 6:22 am)
PostPosted: Tue Jan 15, 2019 5:23 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Let me know how this works out for you. It really speeds up prep time. In the past I have taped freezer wrap (Walmart, big roll, waxy on one side. Or just taped a border. The former took a lot of time. The latter did not protect top against drips. With this, I can get a top sealed up in less than 5 minutes. But Trevor's use struck me as especially interesting. Taping up a fingerboard with frets sucks. This gotta be easier. I'm gonna test some with nitro tonight to see what happens.
PostPosted: Tue Jan 15, 2019 5:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I would not do that. Put it on, do your epoxy, get it off.
PostPosted: Wed Jan 16, 2019 6:20 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I did a nitro spray test... soaked it good. No melting of plastic. I'm doing a soak test in DNA, mineral spirits, and acetone.
PostPosted: Thu Jan 17, 2019 5:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
The plastic passed the soak test. DNA, Acetone, Mineral Spirits for 12 hours. The acetone turned the plastic white, then after it dried it was clear again. That's good news!
PostPosted: Thu Jan 17, 2019 7:56 pm
Last Name: Beaver
City: Lake Forest
Wow, sounds like it will be a great protection layer. It should be much easier to use than masking tape. And it should give better protection. Good find
Joe Beaver
Maker of Sawdust
PostPosted: Sun Jan 20, 2019 10:22 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Anybody tried this yet?
PostPosted: Sat Feb 22, 2020 2:57 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thought I would update my experience with this in the event someone stumbles across this. It worked great at protecting the surface. And in the quick chemical resistance tests I was able to easily remove the product. But in the real life test where it stayed on the guitar for several weeks through the finishing process (finger board in particular), it turned out to be a BEAR to remove. Even with a hair dryer. Even with a week during the epoxy pore fill, it was difficult to get it off the top.
So, unless your project will only last a day or two, I would not use this. I am back to using Reynold's Kitchtens Freezer Wrap (Walmart sells it). Big roll. Shiny side out.
similar to this: https://www.walmart.com/ip/Reynolds-Kit ... t/11027102
PostPosted: Sat Feb 22, 2020 7:46 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Thanks.
Hey Cal, hows it going on your side of the bridge?
Here in Kelowna.
https://www.homedepot.ca/product/robert ... 1000538143
Or most flooring supply shops..
B
PostPosted: Sun Feb 23, 2020 10:06 am
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Hi Brian, just down in Tucson till the end of March, I’ll get hold of you when I get back.
Cal
