It is currently Wed Aug 19, 2026 10:50 pm
PostPosted: Tue Jul 16, 2019 8:53 am
The battery pack of my LR Baggs Anthem doesn't want to stay in place. Saturday night I decided to ditch the factory adhesive in favor of double stick tape and still no luck. It was jostling around inside the body during a rehearsal Sunday morning. I'm installing it in the upper left shoulder of the guitar. Right shoulder is a cutaway.
My thoughts have been to (a) stop trying to defy gravity by adhering it to the side of the right lower bout, and/or (b) try some kind of mechanical bond like a magnet instead of adhesive (just not sure if magnets will mess with the battery or signal).
PostPosted: Tue Jul 16, 2019 10:47 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Loctite ca.
Mike Collins
PostPosted: Tue Jul 16, 2019 11:11 am
First name: Freeman
Last Name: Keller
I use gel superglue to hold the velcro to the inside of the guitar.
PostPosted: Tue Jul 16, 2019 12:40 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I’ve installed a whole bunch of these, but rarely stuck to the guitar side, rather to the back or neck block. The LR Baggs pressure-sensitive adhesive is pretty aggressive — has to be to stay in place while separating the Velcro. I suspect the curved surface of the side might be at least part of your issue. I assume you cleaned the mounting surface?
PostPosted: Tue Jul 16, 2019 8:27 pm
First name: Aaron
Once I started "finishing" my neck blocks with CA, no issues with velcro sticking to it.
PostPosted: Tue Jul 16, 2019 10:04 pm
Part of me worries about damaging the side if I ever want to take it out... The other parts wonders if I ever will. How do you apply it? Is it just a dot? A line of glue? Surrounding the perimeter with it?
PostPosted: Thu Jul 25, 2019 2:27 pm
I always install on the side and never had a problem. You do need to blow out the area, wipe it down with a tack rag and clean it with denatured alcohol.
These users thanked the author dberkowitz for the post: James Orr (Thu Jul 25, 2019 3:19 pm)
PostPosted: Thu Jul 25, 2019 5:33 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
You have GOT to clean the area completely with DNA and let dry. Problem is worse with oily woods. Clean, then clean again. Let dry. Then do not let your fingers touch the area. I have successfully attached to coco and African Blackwood using this approach.
Users browsing this forum: No registered users and 116 guests
