It is currently Thu Jun 26, 2025 2:59 am
 Post subject: bending 'black limba'
PostPosted: Sun Oct 18, 2020 9:20 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I'm using this wood for the first time and I'm fishing for comments/advice about bending the sides in a Fox bender.
Thanks very much.
Peter Havriluk
PostPosted: Sun Oct 18, 2020 12:05 pm
Last Name: Colbert
City: Anacortes
I find it to be an easy bend. I use SS slats, 6” painters paper, and Windex w/ammonia ala Mr, Hall. I thinkness to .085” or until it feels right. My hi temp is 320°, start the waist bend at 280°, then hold @ 260°, then down to room temp, twice.
Good luck, M
PostPosted: Sun Oct 18, 2020 2:30 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Michael, thanks. Nice, complete, list of temperatures and spraying. Much obliged.
Peter Havriluk
PostPosted: Sun Oct 18, 2020 10:21 pm
Yeah, bends easy, no special tricks required...
PostPosted: Tue Oct 20, 2020 10:52 am
Windex? I have to look that one up in the archives ;)
PostPosted: Tue Oct 20, 2020 11:17 am
Last Name: Colbert
City: Anacortes
If I’m remembering correctly John Hall was the first to suggest using windex w/ammonia. I knew about Ammonia for bending but never put the two together. Another side benefit is that the windex evaporates much faster than water. Works like a champ!
M
These users thanked the author Michaeldc for the post: Pmaj7 (Tue Oct 20, 2020 3:19 pm)
PostPosted: Tue Oct 20, 2020 3:26 pm
Hmm...
PostPosted: Tue Oct 20, 2020 3:41 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I've used it on several recent bends instead of supersoft. Worked great. Lightly sprayed the sides and dipped the packing paper strips in it too (squeegeed off).
Make sure to use the Windex Original with ammonia in it.
These users thanked the author CarlD for the post: Pmaj7 (Tue Oct 20, 2020 4:59 pm)
PostPosted: Wed Oct 21, 2020 12:11 am
Last Name: Beaver
City: Lake Forest
If you have had luck bending sapele, then bend black limba the same way.
If Not this works for me.
1. Spray wood well with water.
2. sandwich it from the bottom or as you prefer with: Slat, Blanket, tin foil, wet paper, wood, wet paper, tin foil, slat.
3. Heat up until it sizzles and a little stream shows, modulate the heat to keep it around 300.
4. Slowly bent the waist in.
5. Unplug the blanket and spray water into the waist to cool.
6. Since I put the blanket under the wood on the bender, with the waist bent, the upper and lower bout wood will be above the blanket. I use spring clamps and raise the upper bout sandwich up against the wood. Turn the heat back on and bend as before. Once bent, turn heat off, Cool the waist again, and repeat for the lower bout.
Joe Beaver
Maker of Sawdust
