It is currently Wed Aug 13, 2025 9:52 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: The Slot Head Thread
PostPosted: Thu Jan 21, 2021 4:21 pm
First name: Terry
I've tried some sanding bits in my drill press, and found them to be more problematic than useful. With pressure, the quill seems to loosen and the chuck falls out of the spindle. After a few attempts, I restored to an oscillating spindle sander. I know it's more money, but in the end the desktop spindle sander isn't that expensive, and it's much more effective. And, despite my aversion to the flush trim router, I continue to use it with great results.
PostPosted: Thu Jan 21, 2021 6:45 pm
Some good tips and ways of doing things. I've only made three so haven't gotten carried away. Jig for the tuner holes are LeeValley drill bushings and some maple. I drill most of the waste away on my drill press and then use a single slot plexi template attached with double sided tape and clean up the slots on my router table with a pattern bit. Rat tail bastard file, rasps and dowels with sandpaper for the ramps. The picture was my first slot head which was made from a pine 2" x 4" so didn't take the greatest care with it. The 12 string holes were done with the drilling block that Stew Mac used to sell and then discontinued. It worked great with the 6 on a plate Golden Age tuners. I made the slots intentionally shorter (ahem) to reduce the headstock length. At least that's what I told my sister. Still works fine. I've used the same jig and template since as they work. I use a Veritas edge trimming block plane to get to final dimensions after bandsawing close to the line on the headstock. Works great.
PostPosted: Thu Jan 21, 2021 10:25 pm
SnowManSnow wrote:
For those who do use the luthier tools jig.. which router and bushings do you use ?
I use a Porter Cable plunge router. The bits and recommended bushings are available on their website as I recall.
PostPosted: Thu Jan 21, 2021 10:43 pm
First name: Brad
Last Name: Combs
Same. I use a Bosch plunge router and their recommended bits / bushings for guitar. For uke I use a Dewalt 611 in a plunge base with the smaller bits / bushings.
These users thanked the author bcombs510 for the post: SteveSmith (Fri Jan 22, 2021 6:59 am)
PostPosted: Thu Jan 21, 2021 11:52 pm
One thing to mention is that your bit is rarely perfectly centered in the bushing so you have to be sure that the same side of the bushing is against the same side of your slot on both to be sure they will be perfectly symmetrical.
These users thanked the author Terence Kennedy for the post (total 3): SnowManSnow (Fri Jan 22, 2021 11:12 am) • bcombs510 (Fri Jan 22, 2021 8:44 am) • Colin North (Fri Jan 22, 2021 1:58 am)
PostPosted: Fri Jan 22, 2021 11:12 am
Well I actually ordered my jig yesterday ha. I drank the koolaid
PostPosted: Fri Jan 22, 2021 11:15 am
I talked to ... Glenda? I think on email and they recommended the trim router version. Is that for ease of handling you think ? I’m getting a dedicated router for this as I hate setting up routers for different jobs.
Several have said the plunge version .. I assume for added power. Just want to get the right tool for the right job
PostPosted: Fri Jan 22, 2021 11:29 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
For deep slotting and morticing I recommend going with the biggest router in the shop. You can get away with
using a trimmer, but imo. only if you have to. For me that would be a 3hp plunge. Save the trimmers for binding
and rosette stuff.
PostPosted: Fri Jan 22, 2021 12:30 pm
First name: Brad
Last Name: Combs
You'll like it, it's very versatile and you can get plates for slot head, standard tuners for both uke and guitar.
I use a Dewalt 611 in a plunge base for ukes and the bigger 3HP Bosch plunge for guitars. The reason I went this route is the uke needs 1/4" bit and I didn't have a collet for the big Bosch. :)
Users browsing this forum: doncaparker and 28 guests
