It is currently Thu Oct 31, 2024 5:46 pm
 Post subject: Top crack repair
PostPosted: Sat Jun 25, 2022 11:07 am
Country: Ireland
Small impact crack near the bridge on a cedar top. Not done any repairs but built maybe ten acoustics. Any ideas to start? Lightly built, fair bit of belly behind the bridge. Strings are slack but a bit of a crease with tension at the crack. Image
Sent from my SM-J600FN using Tapatalk
PostPosted: Sun Jun 26, 2022 7:17 am
First name: Josh
Any crease in that region is cause to check for a loose x-brace or tone bar internally. Especially after a sharp impact and definitely if you think you are seeing more belly than you should. Start with a really thorough internal inspection.
These users thanked the author joshnothing for the post: Hesh (Mon Jun 27, 2022 4:51 am)
 Post subject: Re: Top crack repair
PostPosted: Sun Jun 26, 2022 12:24 pm
In regards to repair, determine if there is any internal reinforcement directly under the impact from bracing or the bridge plate. If not, then a small patch might be appropriate.
A steam dent removal process would probably bring the dent closer to level. Also, a little bit of CA would fill the remaining dent and bond the fractures.
These users thanked the author Barry Daniels for the post (total 2): Hesh (Mon Jun 27, 2022 4:51 am) • mike-p (Sun Jun 26, 2022 4:11 pm)
PostPosted: Sun Jun 26, 2022 4:13 pm
Country: Ireland
Thanks Barry, I had to start a new thread to post the inside picture. Im feeling empowered! I'll try to post some more pictures, a lively handmade English guitar in classical style but for steel strings, cedar over Brazilian rosewood.
