It is currently Tue Apr 21, 2026 6:28 am
PostPosted: Sat Aug 27, 2022 12:29 pm
It's my understanding that these are glued in with CA?
Using my standard technique of a slit in cardboard protected by AL foil over the bridge exposing the saddle with a heat lamp simply will not work like it easily does on true vintage hide glue ones. And I mean I got this sucker HOT and just will not budge.
What do y'all do? Just rout it out and start over?
PostPosted: Sat Aug 27, 2022 1:06 pm
I have seen one technique where you saw down the middle of the saddle with a razor saw until you near the bottom. Then squeeze it from the sides with pliers to break the two halves free.
I think I saw this on Frank Ford's site.
These users thanked the author Barry Daniels for the post: jfmckenna (Sat Aug 27, 2022 1:10 pm)
PostPosted: Sat Aug 27, 2022 5:57 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
+1 for Barry’s suggestion. It has worked for me with hard to remove or broken glued in saddles. I have used a circular saw in a dremel tool it worked fine, just take your time.
These users thanked the author Cal Maier for the post: jfmckenna (Sun Aug 28, 2022 9:15 am)
PostPosted: Mon Aug 29, 2022 6:18 pm
Saw through worked like a charm, thanks.
These users thanked the author jfmckenna for the post: gxs (Wed Jan 18, 2023 5:41 am)
