It is currently Tue May 26, 2026 7:03 am
PostPosted: Sun Feb 04, 2024 8:18 pm
Further to my post on tapering the headstock. Because I started with Benedetto's book for my first guitar, I've always tapered my neck with a Safety Planer to the correct taper and thickness prior to carving using a simple jig. Staying away from the centerline while carving results in correct thickness for me. I know many others use a rasp etc. at the 1st and 10th or 12th or so fret to establish taper between the two points. Anyone else doing it like Benedetto with a safety planer?
These users thanked the author Darrel Friesen for the post: Kbore (Mon Feb 05, 2024 6:19 pm)
PostPosted: Sun Feb 04, 2024 8:52 pm
Last Name: Kincheloe
I do it by hand plane after cutting the scarf joint but before gluing on the headstock and heel block. But I leave 1/16" or so to be carved off after the fretboard is on and radiused so I can feel the overall shape and thickness.
These users thanked the author DennisK for the post: Kbore (Mon Feb 05, 2024 6:20 pm)
PostPosted: Sun Feb 04, 2024 8:56 pm
I do it with the safety planer too.
These users thanked the author Jim Watts for the post: Kbore (Mon Feb 05, 2024 6:20 pm)
PostPosted: Sun Feb 04, 2024 9:03 pm
I used to do it with the safety planer as well…
PostPosted: Sun Feb 04, 2024 9:10 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I used to do it with a safety planer, but switched to simply cutting it on the bandsaw. Much faster, way less messy, less intense, and plenty accurate.
These users thanked the author J De Rocher for the post: Kbore (Mon Feb 05, 2024 6:20 pm)
PostPosted: Sun Feb 04, 2024 9:14 pm
Bandsaw for me too.
These users thanked the author Pat Foster for the post: Kbore (Mon Feb 05, 2024 6:21 pm)
PostPosted: Sun Feb 04, 2024 10:25 pm
I made templates for my neck profiles and rough cut close on the bandsaw and do final shaping with the Robosander. The neck keys in via the truss rod slot. The Robosander sands about 1/32” proud of the template so the jig compensates for that.
ImageIMG_1162 by Terence Kennedy, on Flickr
ImageIMG_1163 by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post: Kbore (Mon Feb 05, 2024 6:23 pm)
PostPosted: Sun Feb 04, 2024 10:59 pm
I taper the face of the neck using a power jointer, similar to the way you would taper a table leg. I do that after gluing on the peghead. For slot head classical type necks with scarph joints it can move the scarph line to the "chin" area which I think looks nicer than having it on the back of the peghead.
These users thanked the author Clay S. for the post: Kbore (Mon Feb 05, 2024 6:24 pm)
PostPosted: Mon Feb 05, 2024 2:55 am
Online
Safety planer here.
It's a bit messy chip wise, but I use a shower curtain to catch them and most of the debris just falls on the floor when i shake it off.
These users thanked the author Colin North for the post: Kbore (Mon Feb 05, 2024 6:24 pm)
PostPosted: Mon Feb 05, 2024 5:56 pm
Last Name: Ball
Bandsaw for me.
These users thanked the author ballbanjos for the post: Kbore (Mon Feb 05, 2024 6:24 pm)
PostPosted: Mon Feb 05, 2024 8:39 pm
I flatten the face and top of the headstock with my jointer but Safety planer for the backs.
PostPosted: Mon Feb 05, 2024 8:42 pm
Colin North wrote:
Safety planer here.
I have an old bleach jug cut out to accept chips and then into the 4" dust collector hose. Gets most of it but yeah, it can be messy.
These users thanked the author Darrel Friesen for the post: Kbore (Tue Feb 06, 2024 8:32 am)
PostPosted: Mon Feb 05, 2024 8:44 pm
ballbanjos wrote:
Bandsaw for me.
I laminate most of my necks so bandsaw for sure to cut out the profiles of the laminates but still an 1/8" or so extra left just in case. The Safety Planer takes care of the rest. Just what I'm used to. Makes it easy when carving as I leave a pencil mark down the center and leave it intact while carving which leaves the neck thickness exactly how I want it.
These users thanked the author Darrel Friesen for the post: Colin North (Tue Feb 06, 2024 7:31 am)
PostPosted: Mon Feb 12, 2024 2:29 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
What do you use now?
These users thanked the author Robbie_McD for the post: Kbore (Mon Feb 12, 2024 3:09 pm)
Users browsing this forum: Cal Maier, Colin North and 74 guests
