It is currently Wed May 06, 2026 5:21 am
PostPosted: Sun Sep 01, 2024 9:08 pm
First name: Shane
Last Name: Woonton
City: Wellington
Country: New Zealand
Hi all, it's been years since I was last on here. I'm embarking on a new project to build a 23.5" scale acoustic bass for my 11YO daughter. I'm looking for some direction as this is a new beast for me. A bit of background; I've built 16 acoustics over the years (so I have a reasonable idea what I'm doing ;) and a few electrics, but never a bass.
The string tension is around a third of what I would usually get on a 6-string; 50.2lb vs 148.5lb. Build will be sitka, mahogany b&s and neck, with ebony fretboard and bridge.
Any advice or experience to guide me on changes to bracing patterns, brace heights, string spacing and relief would be appreciated. Even a link to a suitable source, as I'm finding little on my search of the interwebs.
[:Y:]
PostPosted: Mon Sep 02, 2024 12:12 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Shane, It sounds like you're trying to emulate a Taylor GS Mini bass. I think it would be useful to handle and play one before going too deep into a build project.
Peter Havriluk
PostPosted: Tue Sep 03, 2024 5:47 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
Acoustic bass guitars are notorious for being too quiet to compete with more than one guitar played gently, as the body volume is too small. My upright bass is barely large enough for a strong low E!
So you should plan now for amplification, probably a SBT is most natural sounding.
Another issue will be strings - I played a short scale electric bass years back, probably a 26 inch scale, and intonation was a real ssue. Shorter, fatter strings will be worse.
That said, the strings developed for the larger ukulele basses might be worth checking out.
Standard X bracing would be my guess for building, but I have no experience of making an acoustic bass guitar so can't offer other suggestions.
These users thanked the author profchris for the post: Shane Woonton (Wed Sep 04, 2024 10:24 pm)
PostPosted: Tue Sep 03, 2024 8:33 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I’ve built a few acoustic basses with 33” and 34” scales. In order not to make the body way too big, I designed them to have a strong second harmonic so that the ear could fill in the missing low fundamental. It worked quite well. Standing in front, the basses sounded as loud as my upright on the low notes. Standing behind, the volume was quite a bit weaker. The low notes from the upright filled the room. The loud second harmonic was much more directional.
I bought a Fender 30” scale bass just so I could play with the shorter scale and decide if I wanted to make a 30” scale acoustic bass. I wasn’t pleased with the behavior of the low strings at that length, so I haven’t done anything with the concept yet. You string length is even shorter. If you solve the string problem, the second harmonic approach might give you some apparent volume.
Please report if you find a way to do it.
These users thanked the author bobgramann for the post: Shane Woonton (Wed Sep 04, 2024 10:24 pm)
PostPosted: Wed Sep 04, 2024 3:40 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Country: UK
Just checked out the Kala U-bass. It has a 21 inch scale and is reported to work quite well when amplified. Its strings might work for your project.
These users thanked the author profchris for the post: Shane Woonton (Wed Sep 04, 2024 10:25 pm)
Users browsing this forum: joe white and 6 guests
