It is currently Sun Sep 21, 2025 12:27 pm
PostPosted: Tue Feb 05, 2019 3:09 pm
hi,
can't remember where on this forum, but it was posted in the comments for glueing a back strap and it works a treat, so thankyou whoever it was.
I think they bought the stuff from stu mac but I found multi-morph mouldable plastic on eBay for £10.
-just put pellets in hot water,
- take out and mold into long flat peice of plastic
-stick a thin bag over headstock (to keep dry)
- push over back of headstock, use thumbs to get it flat to surface and curve
- when set, remove and use blade to cut off the sides that spilled over the edges, to achieve replica of rear shape
- clamp
- crack open a beer
- done
Sent from my SM-G960F using Tapatalk
These users thanked the author cablepuller1 for the post: Bryan Bear (Tue Feb 05, 2019 3:54 pm)
PostPosted: Tue Feb 05, 2019 3:56 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Awesome! I currently use a caul that is close to the shape and put high density foam between that and the veneer. The foam compresses and makes for a nicer fit than my rough caul alone. I like this much better and I already have some sheets of thermoplastic that I can warm up with the heat gun (no water needed) to make a new, better caul. Thanks!
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: cablepuller1 (Tue Feb 05, 2019 4:34 pm)
PostPosted: Tue Feb 05, 2019 6:57 pm
Nice!
PostPosted: Wed Feb 06, 2019 9:49 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
nice!
Measure Twice,
Karl Borum
PostPosted: Wed Feb 06, 2019 10:54 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
Was this stuff stiff enough that you could clamp right onto it or did you use another flexible caul on top of the molded plastic? Thanks, Bob
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Fri Feb 08, 2019 11:19 am
stiff enough on it's own, sets really hard. removed it and had a perfect bond
Users browsing this forum: Bing [Bot] and 29 guests
