It is currently Sun Sep 21, 2025 6:20 am
 Post subject: Martin 00
PostPosted: Fri Jun 14, 2019 6:31 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Is there a reliably close plane for Martin double 0, 14 fret out there?
Ed
 Post subject: Re: Martin 00
PostPosted: Fri Jun 14, 2019 6:36 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I do have one, Ed, as I just completed a 14-fret 00. Will post details later tonight (am currently on grill duty).
PostPosted: Fri Jun 14, 2019 8:50 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Here you go:
http://www.grellier.fr/en/downloads
The Martin style is the last one listed. Plan is free to download — just take it to your local printer/copy centre.
I used it mainly for the body outline and depths. I revised the neck (as usual), changed to long scale, made a slotted headstock and a pyramid-style bridge. Fits nicely into a standard classical case.
Good luck.
PostPosted: Fri Jun 14, 2019 10:11 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
I just used the Grellier that I modified slightly to fit my aesthetic for curves. Can't say if it's accurate or not, but it has the necessary information.
Tony Thatcher
Bozeman, Montana
PostPosted: Sat Jun 15, 2019 6:30 am
State: Tennessee
Ed
John Arnold & John Hall
PostPosted: Sat Jun 15, 2019 7:25 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
FWIW, if you download the Grellier plan, I was able to get it printed at a blueprint shop for a lot less than taking to to Kinkos or somewhere like that.
I'm not a luthier.
These users thanked the author klooker for the post: Barry Daniels (Sat Jun 15, 2019 10:12 am)
PostPosted: Sat Jun 15, 2019 9:05 am
Last Name: Minch
City: Chestertown
Thanks all - looks like a winner
Ed
PostPosted: Tue Jun 18, 2019 11:33 am
First name: Nathan
Last Name: Peirson
I downloaded the link to the Grellier plan but it appears to be ordinary 8 1/2 x 11. Did I miss something? I discovered it when I was sending it to FedEx to get printed (I print blueprint size drafting files there with little issue). I also tried downloading the ,dfx file but it would only download a weird text file. I have drafting software that will read that type of file but getting it...there's the rub.
Thoughts?
PostPosted: Tue Jun 18, 2019 11:44 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Thoughts?
If your pdf program defaults to “scale to fit”, then it will be shrunk to whatever is your default paper. Otherwise, print “without scaling” will expect A0 paper (841 x 1189 mm). Your printer will know what to do.
Users browsing this forum: Colin North, doncaparker and 27 guests
