It is currently Sun Sep 21, 2025 4:22 am
PostPosted: Thu Jul 18, 2019 2:24 pm
I've got a sheet of Tortoise and a customer who wants it darkened. I was thinking of spraying black nitro on the back side of it, the side that gets stuck to the guitar.
Has anyone done this before or have any thoughts on how to do it. Would nitro on the stick side be a bad idea?
PostPosted: Thu Jul 18, 2019 5:58 pm
Tell him tough. Or he can order another.
PostPosted: Thu Jul 18, 2019 7:14 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I've sprayed clear (Mohawk) on top of tortoise celluloid binding & it hasn't delaminated yet after 5 years.
So in all seriousness, and wanting to cover my arse, I'd say it might be ok.
I'm not a luthier.
PostPosted: Thu Jul 18, 2019 10:24 pm
I would be inclined to use a dye stain in a little bit of lacquer (as a binder ) and use it as a toner on the "stick" side of the pickguard. You might want to spray several light coats (letting it dry in between) so the solvents don't distort the plastic. I would be afraid a black lacquer might make it too dark.
PostPosted: Fri Jul 19, 2019 11:19 am
Well he gave me a big sheet of the stuff and said just go ahead and experiment. So it doesn't come out of my bottom line.
I guess I'll have to play around with a few of these ideas.
PostPosted: Fri Jul 19, 2019 12:46 pm
Another possibility might be to mask off the area around the pickguard and darken the top wood under it. If you have some scraps you could experiment with different paints and colorants and then lay the pickguard material over it to gauge the effect.
Users browsing this forum: Colin North, DennisK and 42 guests
