It is currently Fri Sep 19, 2025 11:16 am
PostPosted: Fri Nov 05, 2021 10:24 am
I'm very close to finishing my build and I'm having trouble choosing a filler that would fill in the grains of my lumber. If you have any experience with these products do let me know.
PostPosted: Fri Nov 05, 2021 11:02 am
I think what you want is a pore filler, none of those are pore fillers.
A pore filler is something like this: https://www.lmii.com/73-pore-fillers
PostPosted: Fri Nov 05, 2021 1:46 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I agree none of the ones shown are pore fillers. In any case You need to go clear or much darker than the wood you are using or you will hide the grain .
PostPosted: Fri Nov 05, 2021 2:04 pm
First name: Freeman
Last Name: Keller
What are your woods? How do you plan to finish them? Do you have cutoffs to experiment on?
PostPosted: Sun Nov 07, 2021 6:03 pm
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
These are some types of wood /pore fillers, oil. water based ,and shellac/ pumice or rottenstone, And there are also more newer ones such as epoxy. or z poxy . Todd stock has a youtube video on pore filling a guitar with epoxy. And there are other methods as well. Pore filling invlves IMHO a learning curve. I started using the oil based product with silica behlens back in the early 80/s and it took time to learn to fill mahogany pores. Good luck !
PostPosted: Mon Nov 08, 2021 5:35 pm
none of them
I use aqua coat Martin uses a very dark filler and hasn't hidden the grain yet ,since the purpose of the filler is to fill pores not cover the grain
My friend Wayne Henderson uses this filler https://www.amazon.com/Elmers-Products- ... 191&psc=1'
he colors it very dark to show the pores he likes that look
These users thanked the author bluescreek for the post: Chris Pile (Tue Nov 09, 2021 9:51 am)
PostPosted: Mon Nov 08, 2021 7:51 pm
John, isn't that Elmers product the same as what the OP is posting? Those products are for when you have errors in your wood work and you can just fill them in an attempt to hide them and in my experience it never looks good. May as well use saw dust and glue.
I like aquacoat very much now too and you can dye that as well.
PostPosted: Tue Nov 09, 2021 6:34 am
that is the pro bond
Wayne uses the regular elmers I don't use that one
I also know people using drywall joint compound
These users thanked the author bluescreek for the post: jfmckenna (Tue Nov 09, 2021 8:41 am)
PostPosted: Tue Nov 09, 2021 9:52 am
Quote:
none of them
I'm with John. Wood filler is for filling nail holes. Leave it for the cabinet makers.
PostPosted: Tue Nov 09, 2021 1:51 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I think pro-bond is Elmers branding for their products when sold at Home Depot.
Bryan Bear PMoMC
PostPosted: Tue Nov 09, 2021 2:29 pm
Finish resin epoxy will work, like what is used to do fiberglass layups. Squeegee on a few coats and sand back to level.
PostPosted: Tue Nov 09, 2021 8:51 pm
filling is part of finish prep so understanding that is part of the solution
I tried about every filler out there. I do find the aqua coat as easy process as I have found yet
The epoxies can leave foot prints under the finish is not done correctly
Aqua coat is simple and you can get a great level and it is easy to color if you want to color it
seal fill seal top coat
PostPosted: Tue Nov 09, 2021 9:00 pm
First name: Lucas
Last Name: Hofer
City: Flandreau
State: Sd
Zip/Postal Code: 57028
Aqua coat is waterbased can you use that the under nitro?
PostPosted: Wed Nov 10, 2021 12:21 am
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Yes. A layer of shellac goes under and over each coat. Check the directions.
