It is currently Fri Sep 19, 2025 11:07 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Sun Feb 20, 2022 3:28 pm
First name: Terry
Alan Carruth wrote:
Terrence:
I'm not questioning your results, just the analogy. With something as complicated as the guitar it's easy to end up doing the right thing for the wrong reasons. There's not even anything wrong with that, until you try to push it too far; things stop working the way you expect, and you don't know why.
Sounds like you are the expert on this subject, so I won't argue your points. All I know is that the time I played a McPherson, there was a difference in the sound compared to anything I had heard before. Maybe that was a "lucky" guitar, but something tells me there's a reason they get the prices they do. And, based on interviews from the founder, he's under the impression that engaging more of the top (among other things) contributes to those results.
So, to whoever started the questions about the elevated fret board, I would not want to discourage experimentation in this area, as it seems to have lead at least one maker to become one of the premier builders in the world.
Now, let's all go build something.
PostPosted: Mon Feb 21, 2022 5:59 am
First name: Josh
Combine your cantilevered fingerboard with a mechanically adjustable neck joint and you may have a flattop that never needs a neck reset…
Users browsing this forum: stumblin and 28 guests
