It is currently Thu Sep 18, 2025 11:14 pm
PostPosted: Wed Jun 01, 2022 8:09 am
Do you cut the purfling rebate first or the binding rebate?? Why?
PostPosted: Wed Jun 01, 2022 8:27 am
I cut the binding ledge first because it's a deeper cut and I feel it is more likely to leave a less perfect edge on the top. In practice I've not really noticed any difference in the edges on the binding or purfling ledges. I expect it depends on how sharp your bits are; mine are sharp.
These users thanked the author SteveSmith for the post: frwilliams (Wed Jun 01, 2022 10:02 am)
PostPosted: Wed Jun 01, 2022 8:50 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I think it should depend, at least in part, on how your router registers against the side for the across-the-plate depth of cut. Some setups have a bearing that registers against the part of the side that is right under the cut. If that is the setup you have, then you should cut the purfling ledge first. If you cut the binding ledge first, that ledge might interfere with where the bearing would normally ride.
If your setup registers against the side much lower than what I describe above, then I think it is up to personal preference.
These users thanked the author doncaparker for the post: frwilliams (Wed Jun 01, 2022 10:02 am)
PostPosted: Wed Jun 01, 2022 9:02 am
A good point Don.
PostPosted: Wed Jun 01, 2022 10:42 am
Yes, what Don said, but other than that’s I don’t think it matters, depending on which bit is sharpest.
I excess route with a .060x .200 cut, then fare the sides, then cut whatever binding channel, then cut the purfling channels. I use the carriage and tower system, and I have a row of four routers, one for excess, main binding, top purfling, and back purfling. All you ever need to do is swap out the bearings, and make sure you’re using the right one. It’s a bit of an expensive upfront cost with four routers and four cutters, but, since each cutter barely gets used, they last a very long time. The dullest one is always the excess cutter as it does the bulk of the work, but if it’s channels are fuzzy it’s ok, as they’ll be touched up again with the binding and purfling cuts.
I like (love) this system as you only have to make test cuts for depth once, when you put in a new cutter.
These users thanked the author meddlingfool for the post: frwilliams (Thu Jun 16, 2022 9:04 am)
PostPosted: Wed Jun 01, 2022 11:04 am
As a side note you can buy tall purflings so you only have to make one cut :)
PostPosted: Wed Jun 01, 2022 12:08 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I've always cut the purfling ledge first for the same reason Don mentioned above. It's never presented any problem.
