It is currently Sun Sep 21, 2025 2:12 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 04, 2018 9:48 pm
Last Name: Kincheloe
Clay S. wrote:
And then there is the nonluthier approach:
http://www.youtube.com/watch?v=V2xnXArjPts
That's the video I cite as proof that nut compensation is necessary :) Without it, the best you can do is sacrifice some accuracy on the open B to reduce problems elsewhere.
PostPosted: Wed Dec 05, 2018 1:40 pm
I use a variation on the 'rod' approach. I make a saddle that is wide enough to allow for needed adjustment, and start out with the saddle top flat. Each string is brought up to pitch separately, with a short cutoff length of B string under it, across the top of the saddle. I move the break point back and forth until I get the correct intonation, and mark it. Once all of the string offsets have been determined the saddle is removed and the top filed to get the peak to run along that line. I use a pre-determined set of offsets at the nut when doing this: I have found less variation in nut offsets than saddles. Most of the variation is due to the influence of top resonances, which seems to be greater at the saddle end, as you might expect.
