It is currently Wed Aug 20, 2025 8:51 pm
 Post subject: Bending herringbone
PostPosted: Tue May 24, 2016 3:55 pm
Hi
Going to be using herringbone purfling for the first time..
Anyone got any tips for shaping to body?
Should I use it dry on bending iron or soak it and try and shape it
 Post subject: Re: Bending herringbone
PostPosted: Tue May 24, 2016 4:19 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I dry bend it on an iron, maybe a spritz of water. If it is made by Gurian Instruments, I find it is easy to bend without delaminating. It does want to twist bending it on edge, but I still find it manageable. I know, at least at one time, Gurian supplied a lot of the lutherie outlets.
These users thanked the author johnparchem for the post (total 2): Ken Grunst (Wed Jun 01, 2016 8:07 pm) • cablepuller1 (Wed May 25, 2016 12:29 am)
PostPosted: Tue May 24, 2016 4:57 pm
Ken Cierp
These users thanked the author kencierp for the post: cablepuller1 (Wed May 25, 2016 12:29 am)
PostPosted: Tue May 24, 2016 5:00 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
i make my own herringbone and use Titebond 3. even with TB3 i prefer not to use water while bending it. what i found helpful was wrapping the HB in aluminium foil. It doesn't need much heat to bend, i keep my ibex iron around 4 (IIRC). of course it helps if it´on the thin side.
good luck!
miguel.
These users thanked the author mqbernardo for the post: cablepuller1 (Wed May 25, 2016 12:30 am)
PostPosted: Tue May 24, 2016 7:00 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
Using my router, I cut a channel to the shape I want (the channel depth is slightly less than the thickness of the purfling) and then use a clothing iron (no water) to make it take the shape of the channel. I then press it in the channel for like 15 mins with a piece of plywood or something.
These users thanked the author Nils for the post: cablepuller1 (Wed May 25, 2016 12:30 am)
PostPosted: Tue May 24, 2016 7:44 pm
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
I have done this many times. Soak for 10 minutes and bend to form. Let dry and that's it.
Michael
These users thanked the author Michael for the post: cablepuller1 (Wed May 25, 2016 12:30 am)
Users browsing this forum: Ken Lewis and 43 guests
