It is currently Sun Sep 21, 2025 4:09 pm
PostPosted: Mon Dec 03, 2018 8:23 am
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
A Gibson 57 Country Western came in for repair and it is in brought shape. Owner, at one time, had sanded the bridge down to compensate for a much needed neck reset. I have been searching for a left hand reverse pin belly up bridge. Anyone know where I can get one.
PostPosted: Mon Dec 03, 2018 9:11 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
You might consider contacting Allparts to ask if they have a stock left hand version of their offered reverse belly bridge, but I doubt you will find a left-handed one, and even more doubtful they would have it in Brazilian rosewood. A custom bridge is an option as the link below reveals, but at close to $60 (and likely more in BRW), an expensive one:
https://www.ebay.com/itm/New-Gibson-B25-Bridge-Replacement-Polished-Rosewood-Gorgeous-Custom-Bridge/301046309465?hash=item4617c22259:g:TgoAAOxyRhBSsJTp:rk:5:pf:0
These bridges are of course quite easy to make with a 2" diameter sanding drum or spindle sander and some way to mill the saddle slot (see the related current thread). The original would serve well as a template, and Brazilian rosewood blanks of proper size can be had on auction sites for reasonable price. The Gibson bridges are not nearly as challenging to make as the Martin 1930's or 1940's belly bridges, and much simpler than the various pyramids.
- Beth Brower
PostPosted: Mon Dec 03, 2018 9:45 am
First name: Victor
Last Name: Seal
City: Osseo
That is my next option.
PostPosted: Mon Dec 03, 2018 11:24 am
Another option might be to fill the saddle slot on a right handed bridge and route a new one.
PostPosted: Mon Dec 03, 2018 12:36 pm
First name: Freeman
Last Name: Keller
I actually just replaced the plastic bridge on an old LG-1 with an Allparts rosewood bridge. The pin holes happened to be in the correct place relative to the footprint and were the correct spacing but the saddle was not. I filled the slot and routed a new one in the correctly intonated location for right hand, it would be easy to do a lefty (the pin holes were in a straight line). I did a little write up at the repair sub forum, there are several good suggestions there
viewtopic.php?f=10137&t=51212
(I miss labeled the thread J-45 because thats what the owner told me).
There are also some good vids by David Collins and Dan Erlewine
PostPosted: Tue Dec 04, 2018 8:40 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Make one.... That's how I handle these oddball bridges. If you need someone to make it for you just PM me.....
Brian
Users browsing this forum: Dave Rickard and 32 guests
