It is currently Sun Sep 21, 2025 2:13 pm
PostPosted: Sun Mar 03, 2019 3:50 pm
So I’ve done ports with a reinforcement where I’ve basically laminated that area, but what would be the downside in reinforcing it with epoxy and a fiberglass mesh?
PostPosted: Sun Mar 03, 2019 3:52 pm
Uglieness?
These users thanked the author meddlingfool for the post: SnowManSnow (Sun Mar 03, 2019 7:45 pm)
PostPosted: Sun Mar 03, 2019 4:16 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Probably lots of ways to skin that cat. I have seen guitars that just had a hole drilled in the side without any reinforcement and it worked fine. CF plastered on the inside with epoxy would help prevent cracks from originating at the hole. But I agree with Ed that it might not be the best look. I laminate a piece of side cut-off, bent to fit, to make a cross-grain patch inside. It can look good if you sandwich a contrasting veneer in the middle which gets revealed as a ring at the opening, and can tie into your purfling scheme. Binding the hole looks classy too, and affords extra protection to the rim.
PostPosted: Mon Mar 04, 2019 12:16 am
What Mark Mc said... [:Y:]
PostPosted: Mon Mar 04, 2019 10:37 am
I'd prefer cut out a soundport backed with just about any wood rather than fiberglass.
PostPosted: Mon Mar 04, 2019 8:49 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
If you are binding the hole no one will notice. If they go looking inside with a mirror they will see it so if you choose that route, just do a clean job of it.
I laminate cross grained wood and bind the hole. It looks good and works well.
