It is currently Sun Sep 21, 2025 8:11 am
PostPosted: Fri Jun 07, 2019 10:23 am
I’ve gotten by this far, but there has to be a more efficient way to level the drum on my 10-20. The issue seems to be that the rollers inhibit access to the bottom of the drum, so it makes it hard to see / adjust correctly..
How do you guys do it??
PostPosted: Fri Jun 07, 2019 10:48 am
Run something (4mm MDF?) through it, compare height both sides.
You can use a similar board as a backer if you out sandpaper on one side.
PostPosted: Fri Jun 07, 2019 10:49 am
I don't have that specific machine, but on my delta, I concoct a way to lift the rollers up out of the way...
PostPosted: Fri Jun 07, 2019 11:10 am
Online
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Here is what I did when I owned that machine:
1. Take off the sandpaper (for the moment).
2. Put the rollers up on blocks that are thicker than whatever you use to measure the distance from the drum to the table. That way, the rollers are out of the equation.
3. Use two identical setup blocks (purchased, not made), one at the far right of the drum, one at the far left. Fidget with the tilt until the drum touches both setup blocks without severely pinching either of them.
4. Put the sandpaper back on, run test pieces, see if any tweaks are needed.
These users thanked the author doncaparker for the post: James Orr (Sat Jun 08, 2019 1:54 pm)
PostPosted: Sun Jun 09, 2019 6:37 pm
Hi,
there is a method on the joe woodworker site that I've used successfully to adjust my sanding drum. I have a 22-44 and the method works well but don't know how well it would work on much shorter drum like your 10-20. It's under Articles->Category: Woodworking and More on that site and called Performax Sander Tips.
Steve.
These users thanked the author steveci for the post: SnowManSnow (Sun Jun 09, 2019 7:03 pm)
PostPosted: Sun Jun 09, 2019 9:08 pm
I have a Jet 16-32 That I set up to be slightly non parallel. The open end is about 1/32" higher than the motor end. For tops and backs, just flip end for end and you wind up slightly thicker in the middle with no strange marks on the open end for an incomplete width.
PostPosted: Sun Jun 09, 2019 10:03 pm
My 16-32 is setup like this too, but only by about .005" thicker on the open end. I wouldn't want much more taper than that.
PostPosted: Mon Jun 10, 2019 8:54 am
I think this is the article that steveci is referring to. It's definitely the most clever set up I've seen for this job:
https://www.joewoodworker.com/performax.htm
I simply follow the instruction that came with my Jet sander. But then I follow up simply by running a wide board through it and measure the thickness on either side with a caliper and adjust as necessary.
PostPosted: Mon Jun 10, 2019 10:12 am
Yes, that the method. I just used a small 9 volt battery, though. It was sufficient to light the LED.
Steve.
Users browsing this forum: doncaparker and 23 guests
