It is currently Sat Sep 20, 2025 9:54 pm
 Post subject: adjustable compensation
PostPosted: Fri Jan 10, 2020 12:36 pm
https://www.ebay.com/itm/10-string-Acou ... SwF~1eB8tf
The above 10-string, double course guitar bridge has a table to set floating "saddles" for each pair of strings.
PostPosted: Fri Jan 10, 2020 12:42 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
So they float like archtop bridges? I would imagine they would move as you tuned the string to pitch.
Brian
These users thanked the author B. Howard for the post: wbergman (Fri Jan 10, 2020 4:32 pm)
PostPosted: Fri Jan 10, 2020 1:02 pm
Comes to mind that I mentioned a few years ago about a classical builder who drilled individual holes part way into the bridge to set slotted brass pins for each string. I suppose something along that line could let you adjust each string with a new pin, without having to interfere with adjacent strings.
PostPosted: Fri Jan 10, 2020 1:29 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
wbergman wrote:
https://www.ebay.com/itm/10-string-Acoustic-Guitar-Brazilian-Viola-Caipira-Brazilian-Rosewood/264592901842?hash=item3d9af746d2:g:UdQAAOSwF~1eB8tf
I'm wondering why you referred to them as "floating" saddles. The bridge isn't described in the listing. Did you find info about how Vergilio Artur de Lima makes bridges like this somewhere else?
These users thanked the author J De Rocher for the post: wbergman (Fri Jan 10, 2020 4:32 pm)
PostPosted: Fri Jan 10, 2020 4:32 pm
No, I just jumped to conclusion that it did not look like the little saddles were recessed. Maybe they are attached.
PostPosted: Fri Jan 10, 2020 5:35 pm
First name: Jay
City: Bothell
State: Washington
The compensation scheme is interesting/puzzling. I wonder what the reason is for the angle of the saddle for the bass-side string pair. Based on the builder's website this use of separate saddles and how they are set for compensation is standard procedure for him on this instrument. I looked up pics of violas caipira from other makers and they use single piece saddles similar to what you would typically see on a twelve-string guitar.
Here's a photo of a part of a "14-string double-tuned guitar" of his. It would interesting to see the rest of the instrument to see what's going on there.
These users thanked the author J De Rocher for the post: wbergman (Fri Jan 10, 2020 6:16 pm)
Users browsing this forum: No registered users and 43 guests
