It is currently Sun Sep 21, 2025 2:17 am
 Post subject: Flamenco Blanca build
PostPosted: Wed Jan 15, 2020 6:47 am
First name: Martin
Last Name: Taylor
City: Central Coast
Hi all, here are a few pics of my Flamenco Blanca build. Back and sides, Macrocarpa (Monterey Cypress), top, Engelmann Spruce, Neck, Australian Red Cedar, Rosewood bindings, Planetary pegs, 5 fan brace with closing braces, tantalones in King William Pine for top linings and macrocarpa solid strip for back linings.
Martin Taylor
http://martintaylorguitars.com.au
These users thanked the author martintaylor for the post: Michaeldc (Wed Jan 15, 2020 8:21 am)
PostPosted: Wed Jan 15, 2020 8:44 am
That's a beauty right there, nice job!
PostPosted: Wed Jan 15, 2020 8:49 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Nice looking Flamenco! I have one that I am building on the bench right now.
PostPosted: Wed Jan 15, 2020 9:49 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Really nice. Did you make the binding/rosette?
Me likey. I had a question, why do classic guitars have the tantelones,
instead of kerfed linings?
Is it tradition, or is there another reason?
Just curious.
Alan
PostPosted: Wed Jan 15, 2020 10:29 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Very creative !!. Also have one in the mold birds eye willow back and sides. Englemann top
PostPosted: Wed Jan 15, 2020 11:18 am
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
Alan
If you're using a solera to put a dome in the top, using tentellones allows you to let the top float on the sides (very little pressure is applied during gluing). If there are gaps between the sides and top the tentellones bridge them. Ideally tentellones should have a slight angle (we use 2 degrees) where they contact the top to conform to the dome created by the solera.
These users thanked the author jshelton for the post: Pmaj7 (Wed Jan 15, 2020 2:55 pm)
PostPosted: Wed Jan 15, 2020 2:56 pm
Beautiful! I see a flamenco in my queue.
PostPosted: Wed Jan 15, 2020 4:51 pm
First name: Martin
Last Name: Taylor
City: Central Coast
Just curious.
Alan
Hi Alan,
Thanks. the main reason I use tantelones on the top for a flamenco is based on the sound I am trying to achieve. The old adage that a guitar must be better because it has lots of sustain (which isn't necessarily true anyway) is the opposite when designing and building a flamenco. The style of playing a flamenco demands very quick, crisp notes and you want to do everything to reduce sustain. Reduced weight is also a target as the lighter the guitar is, the quicker the sound (generally). So, this build comes in at 1091g (2.4 lbs) which is under my target maximum weight of 1.2 - 1.3 kg.
Martin Taylor
PostPosted: Wed Jan 15, 2020 5:05 pm
First name: Martin
Last Name: Taylor
City: Central Coast
oops, didn't answer this bit
I bought the straight strips and then cut them up into small sections to make the rosette. It was fiddly but a start to making one completely on my own (which will happen)
Martin Taylor
PostPosted: Wed Jan 15, 2020 8:11 pm
First name: alan
City: Santa Rosa
State: ca
Thanks guys for the tantelone info.
Lighter/faster decay, very interesting.
I'm trying to build with less bass, and quicker decay, for recording purposes, so,
I'll put that one in my thought bucket.
Alan
