It is currently Sat Sep 20, 2025 7:54 pm
PostPosted: Thu Apr 16, 2020 11:23 am
First name: David
Last Name: Scheckman
City: Plainfield
State: VT
Zip/Postal Code: 05667
As I was laying out the bridge location on my current build (only my second) I realized I misplaced the bridge plate. Rather then centering it under the string holes I centered it under the saddle. So it’s about 1/4” off the standard location. There’s still plenty of plate ( 1/8” thick x 1 1/2” wide maple) where the sound holes will go through to protect the top. If I use a 1” wide bridge (pyramid) the lower side of the bridge will line up with the edge of the bridge plate. It’s a 00 size 12 fret short scale. Will this result in any significant issues with sound or structure? Thanks for any help.
David
PostPosted: Thu Apr 16, 2020 11:52 am
First name: Danny
Last Name: Vincent
As long as the pin holes have enough meat to support the ball ends, you should be fine. You could lighten up on the plate in the future. It does't really need to be that wide for a 1" bridge. And you could thickness down a bit. I use .100 and radius the plate.
PostPosted: Thu Apr 16, 2020 12:07 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
So, there is bridge plate under the whole bridge? It should be fine. I once had the bridge plate so far off that I felt it wise to add another strip of bridge plate material up against it, so that there would be bridge plate under the whole bridge. I don't make that mistake any more.
PostPosted: Thu Apr 16, 2020 1:02 pm
First name: David
City: Plainfield
State: VT
I could add a little width to the bridge in front of the saddle just to add glue surface. Is there a liability to doing that? The saddle to hole relationship would have to stay the same as in a traditional pyramid bridge to keep the bridge fully over the plate. I assume a traditional pyramid bridge has an acceptable break angle.
PostPosted: Thu Apr 16, 2020 2:45 pm
Last Name: Parker
City: Charleston
I’m no expert, but I make my pyramid bridges 1 1/4” wide instead of 1” wide. I’m not trying to match an historic instrument; just building my own. I think it looks good, and I like the extra gluing surface area.
PostPosted: Thu Apr 16, 2020 6:07 pm
no need I have seen martins with the front of the bridge off the plate by almost 1/4 in it is more important you have ball end support on the plate
PostPosted: Thu Apr 16, 2020 6:56 pm
First name: David
City: Plainfield
State: VT
How about if the back end of the bridge hangs over the bridge plate? What would be the most overhang that is acceptable? Assuming the ball ends of the strings have good contact with the bridge plate.
PostPosted: Thu Apr 16, 2020 7:05 pm
if the pins are secure on the plate overhang is minimal
Users browsing this forum: No registered users and 57 guests
