It is currently Sat Sep 20, 2025 5:11 pm
PostPosted: Fri Sep 04, 2020 12:25 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I've been musing...I suspect that strings in a pair are separated farther than they need to be in order to fit the strings on a 12-pin bridge. If 12 strings can be paired on a six-pin bridge, how close to each other can they be within each pair? Taylor's offering this, and I'm in the middle of a 12-string build right now. I'm guessing that I could use the pairing distances at the nut, but I don't know if that's possible when with 12 pins the strings are farther apart at the saddle than the nut.
I'd appreciate any insight into this.
Thanks!
Peter Havriluk
PostPosted: Fri Sep 04, 2020 7:35 pm
First, let me say that I have never built a 12-string. It is possible to use a 6-string bridge with a 12-sring design by putting each pair in a single hole. The ones I've seen have had two slots in the string hole and/or notches in the saddle. The main consideration would be: how close together can the strings get (both each in a pairs and each pair) before the strings start interfering with each other ?? I suspect the big companies have tried and failed to do much better. 12-strings can be difficult for many to play because of the neck widths and a method to narrow them would help sales.
PostPosted: Fri Sep 04, 2020 7:47 pm
First name: Freeman
Last Name: Keller
I space them about 10 thousands at both the nut and bridge. I do pinned bridges with two pins and just ramp the string path and I have built tailpiece guitars with notches in the saddle to set the spacing. Its really no difference than any other multiple course instrument - mandolin for example.
There actually are players, I think Chris Proctor is one of them, who can pick individual strings within a course. I heard he likes them close at the nut and a bit wider at the saddle. One thing that I really enjoy is the difference in sound when you pick up on the course or down, Kottke uses that very effectively.
I have not tried a two-string per pin guitar yet - I guess I don't see any reason to.
PostPosted: Fri Sep 04, 2020 9:40 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
I bookmarked this awhile back, maybe it will answer your questions.
http://www.luthiersforum.com/forum/viewtopic.php?p=193775#p193775
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
Users browsing this forum: No registered users and 78 guests
