It is currently Sat Sep 20, 2025 2:29 pm
PostPosted: Wed Sep 02, 2020 5:18 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
For side dots I was wondering if there's a way to calculate where to place them so that after radiusing the fretboard they don't end up too close to the surface of the fret board. Especially since I haven't settled on one radius.
Or to put it another way, how would one go about calculating how thick a 1/4" fret board will be at its edges after being radiused...
PostPosted: Wed Sep 02, 2020 5:55 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Radius then put them on. Bam!
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: Conor_Searl (Thu Sep 03, 2020 11:09 am)
PostPosted: Wed Sep 02, 2020 6:40 pm
Last Name: Kincheloe
You could use this http://liutaiomottola.com/formulae/sag.htm
I just position all the marker dots a constant distance from the bottom surface of the board and assume it will all go according to plan. About 2mm to dot center, so 1mm between the glue line and the edge of the dot (eyeball it... if it looks right, it's as precise as it needs to be)
These users thanked the author DennisK for the post: Conor_Searl (Thu Sep 03, 2020 11:09 am)
PostPosted: Wed Sep 02, 2020 7:59 pm
First name: Brad
Last Name: Combs
Sadly, I’ve spent way too much time on this and there are tools that help (aka Elevate tool), jogs I’ve built, but in the end Dennis is right in my opinion. Even on boards where it’s not consistent thickness all the way down, if the dots are the same distance from the bottom it looks good.
These users thanked the author bcombs510 for the post: Conor_Searl (Thu Sep 03, 2020 11:09 am)
PostPosted: Thu Sep 03, 2020 3:38 am
It's fairly easy with this calculator https://www.liutaiomottola.com/formulae/sag.htm
If you use this for the FB width and radius at the nut, and then for the FB width and radius at the last dot, the difference in the results will give you the taper in the FB.
Or of course you could just measure your radiused FB at the edges with a caliper, easy peasy.
These users thanked the author Colin North for the post: Conor_Searl (Thu Sep 03, 2020 11:09 am)
Users browsing this forum: Alan Carruth and 28 guests
