It is currently Sun Sep 21, 2025 2:45 am
PostPosted: Tue Jan 26, 2021 1:04 pm
Not too bad.
Made for a hybrid I'm finishing for a student because of the Pandemic.
A classical style bridge in BRW with a 12 hole tie-block, capped with ABW veneer.
Turned out at 19.5 grams.
These users thanked the author Colin North for the post: Michaeldc (Tue Jan 26, 2021 2:34 pm)
PostPosted: Tue Jan 26, 2021 2:14 pm
looks nice. It looks like you used a router for the ends.
I rough classical bridges out on the table saw and finish the ends with a file. The router looks like it would make quick work of it.
I know others are using 12 hole bridges (I think some even use 18 holes) Does it give more break angle? How do you tie the strings?
PostPosted: Tue Jan 26, 2021 2:32 pm
I cut the Saddle slot and in channel front of the the tie-block with a router, and then chiseled the ramp.
The ends (wings) waste were cut with a bandsaw to 10 mm holes drilled (up against a block) at the saddle slot ends and finished with a Japanese rasp/scraper/abrasive.
Tying the strings, easy, here -
https://www.youtube.com/watch?v=Kt6mrDP5NGA&t=532s
These users thanked the author Colin North for the post: Clay S. (Tue Jan 26, 2021 11:16 pm)
