It is currently Sat Sep 20, 2025 7:13 am
 Post subject: Chisel grind
PostPosted: Mon Feb 01, 2021 8:22 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
After fitting the dovetail on my build I got think. Almost all of my chisel work on guitars is a paring action. Since I have a mortising set, I'm considering changing my regular chisels to paring or at least reducing the angles somewhat. What is a good angle to shoot for?
Hutch
 Post subject: Re: Chisel grind
PostPosted: Mon Feb 01, 2021 8:46 am
First name: Terry
I have 25 on my bench chisels. You could go a little lower, but it's more about sharpness at that point. Plus I wouldn't want to weaken the edge, because you always end up doing a little "prying" when pairing sockets and what-not.
PostPosted: Mon Feb 01, 2021 10:26 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I like about 25 for the primary grind, the a bit more for the secondary bevel. I never hit them harder than a tap with a small palm mallet - in the shot at the right
PostPosted: Mon Feb 01, 2021 10:33 am
I do 25/30 on most and reserve 20/25 for one paring chisel, used for braces and miters usually.
PostPosted: Mon Feb 01, 2021 10:44 am
Pairing chisel are traditionally set at 20 degrees. The edge doesn't last to long.
These users thanked the author Jim Watts for the post: Pmaj7 (Mon Feb 01, 2021 12:22 pm)
PostPosted: Mon Feb 01, 2021 3:50 pm
Bench chisels are general utility tools - they can be used for paring or light chopping without modification. Paring chisels have longer thinner blades which are sometimes "cranked" to allow you to get flatter to the work. Rather than regrinding your bench chisels you might buy one 1/2 inch paring chisel instead. Although they are ground at a lower angle I think it is the longer blade that makes the biggest difference for paring.
PostPosted: Tue Feb 02, 2021 9:19 am
First name: Ken
Last Name: Nagy
City: Goodrich
I've ground all of my chisels to about 25 degrees, and my fingernail gouges that are like chisels to 20 degrees or so. I just use those for mostly smoothing, and carving the edge work, and carving scrolls. The angle on the 6mm chisel digging out the deep mortise in a violin pegbox cuts very well, and it is ready to smooth up the sides and bottom in about 15 minutes. Even my scrapers are at 20 -25 degrees. I don't roll burrs on them. I use every tool like scrapers at times.
I don't notice any problem at all. The only thing that I notice is that they feel sharper. That's not a bad thing.
Why be normal?
PostPosted: Tue Feb 02, 2021 11:23 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Swiss paring chisels 17 deg for softwoods 20 for hdwds reg chisels 25 for softwoods and 30 on the narex cryo for hdwd. 35 for mortise chisels in hdwd.
