It is currently Mon May 04, 2026 6:46 pm
 Post subject: Neck Bow
PostPosted: Fri May 07, 2021 10:19 am
First name: Corey
I posted this in the electric forum but, this kind of seems like a universal problem and figured Id get a little more traffic here to help me out.
I'm working on a Tele Build for my daughter. I did a two piece neck and head stock with a scarfed joint as suggested here. (Mahogany & Ash) After routing and getting it sanded I noticed the neck has a bow to it. If it was complete with the truss rod and fretboard it wouldnt be a big deal as I could simply adjust it. Any ideas to get this straight before I continue installing the truss rod and fretboard? Pics file size are too big on my phone to attach, but from end to end there's probably a good 1 to 2mm bow.
Also, I should mention the truss rod slot has already been cut and fitted, along with the routing of profile of the neck is complete. Otherwise I could have maybe got away with running it through a jointer a few passes but its already at its thickness of 3/4".
 Post subject: Re: Neck Bow
PostPosted: Fri May 07, 2021 6:57 pm
I am not an expert in this at all--zero experience with this problem. However, it seems to me that if you think it would be OK if the truss rod were in and the fingerboard on, then why can't you just install the rod and glue on the fingerboard. If you support the assemble with rigid, straight boards while you glue and clamp it, if should somewhat conform to the flat surfaces.
I am reminded of a recent ruin that I did. I built a uke and had the neck so well aligned with the body that I decided to fret the fingerboard before installing it. For a caul on the fingerboard, I used a rigid thick board and wrapped a little tape on one end to be sure to distribute clamp pressure along the entire fingerboard. Well I clamped that down tight and the fingerboard and neck bent back and dried with a reverse bow. So, your assembly will take on whatever curve you force on it before the glue dries--I think.
PostPosted: Fri May 07, 2021 9:03 pm
First name: Corey
Essentially I think that could work. I wish I could post pics on how bad the bow is. Its not that bad but, I'm just afraid of getting all that glued up and it being no good.
PostPosted: Sat May 08, 2021 4:12 am
Do you need 3/4" in the middle of the neck, remembering it will be tapered?
Using epoxy will resolve any potential warping/bending issues with gluing FB.
PostPosted: Sat May 08, 2021 7:56 am
First name: Corey
I will be taking that 3/4" down a little on the back of the neck but not too much.
And epoxy. Do you mean putting the FB on with epoxy?
PostPosted: Sat May 08, 2021 2:34 pm
If you take 1/8" of the neck at the nut end, and nothing at he other end (i.e. keep it at 3/4") you will reduce the middle by 1/16"
This could be used to remove a back bow of ~1.5mm if planing the top surface of the neck.
Yes, gluing the FB on with epoxy. I, and several others here use epoxy to prevent water base glue warping/ bowing the neck.
TR slot can be deepened with a a router plane, or chisel if you prefer.
PostPosted: Sat May 08, 2021 3:34 pm
First name: Corey
Won't epoxy crack with any possible warping in the future?
PostPosted: Sun May 09, 2021 1:21 am
Not really, never heard of any failure if epoxy is properly mixed and surfaces roughened as per instructions.
Try thinking epoxy/fiberglass boat (which has wooden internals epoxied in) flexing in heavy seas.
PostPosted: Sun May 09, 2021 9:04 am
First name: Corey
Ok. So you obviously cant just use a simple two part epoxy have to go find something with a long cure time thats pretty flexible.
PostPosted: Sun May 09, 2021 9:12 am
I tried to repair a spindle back chair with epoxy, per instructions from professional woodworker. It failed rather quickly.
PostPosted: Sun May 09, 2021 10:07 am
The fretboard adds a lot of stiffness to the neck, so you don't really want to have a "flexible" glue joint. I use West system, but there are several other good choices.
Epoxy is used to glue things to (wood, metal etc.) and repair polyester boat hulls because it adheres to polyester better than polyester adheres to polyester.
PostPosted: Sun May 09, 2021 10:30 am
First name: Corey
I guess flexible is the wrong word really but, I guess MORE flexible than a short cure epoxy that easily cracks. I guess I'd rather have a fingerboard/neck flex a little bit than have the epoxy crack and have the board eventually peel off. Just from my experience in knifemaking the type of epoxy and what your using it on is very important.
PostPosted: Wed May 12, 2021 5:56 pm
I believe the term 'structural epoxy' is what is used. There's a few on the market. IIRC, Mario fretted the fingerboard. put a half inch block under each end and clamped the center down to the workbench. This gave a flat fingerboard with the frets in and then used epoxy to glue it on the neck. No bowing. Michael Greenfield uses structural epoxy as well.
Rather have a bottle in front of me than a frontal lobotomy
PostPosted: Wed May 12, 2021 7:10 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I think I see some amount of overthinking and problem avoidance. I don't try to compensate for a problem during a build. I do try to fix a problem before proceeding. OP seems to have a neck that's not flat. I would be very uncomfortable about continuing work on that neck and trying to compensate for the deformation. OP didn't mention whether that neck was quartersawn or flatsawn. Might be the source of the problem if the neck was flatsawn, And the neck wood might just have come by its deformity during fabrication. I'd stop and if I had to, make another neck that's flat before attempting to install a fingerboard. Life's tough enough already.
Peter Havriluk
PostPosted: Thu May 13, 2021 1:03 pm
First name: Terry
chair joints are the hardest joints to make well, and keep tight over the years. Typically, once they loosen, you need to re-make the spindle and re-cut the mortise if you really want it to last more than a few months. Chair joints also endure the most stress of any joint in woodworking that I know of... (never made a laminated cross-bow though:-). If done correctly, the glue isn't really doing much... if any thing. But, this isn't a furniture making thread!
For guitars, we use "Bob Smith 206 Slow Cure Epoxy" but I've also used small bottles of high-strength 30-min that you can get from ACE or similar. We only put epoxy under fret boards and for shell inlay... specifically for the reason mentioned above, avoiding moisture in the neck.
All that said, my vote would be the suggestion to use the jointer in increasing partial passes to reduce the thickness at the nut until you are flat... assuming you can afford to lose enough wood for that to work.
Users browsing this forum: Powdrell1 and 14 guests
