It is currently Thu Sep 18, 2025 7:12 pm
 Post subject: Teflon Strips
PostPosted: Mon Mar 13, 2023 11:08 am
First name: Ellen
Last Name: Aulson
City: Lusby
Zip/Postal Code: 20657
Does anybody know where to buy teflon strips in bulk for purflng beside NC Solutions? They can not ship for an unknown amount of time. Thanks.
Duke of Pearl
410.231.2641
dukeofpearlllc@gmail.com
www.dukeofpearl.com
 Post subject: Re: Teflon Strips
PostPosted: Mon Mar 13, 2023 11:53 am
Last Name: Bradley
Country: United Kingdom
I had a problem getting these here in the UK a while back, so I bought some 2mm thick teflon sheet and cut strips of approximately 2.5mm on the bandsaw. Worked well, and cheaper as I recall. Just a thought. Mike
PostPosted: Mon Mar 13, 2023 3:50 pm
These don't have to be Teflon; I've made no-stick strips out of polyethylene from old cutting boards. It jst has to be flexible, and not stick to water-based glues.
PostPosted: Mon Mar 13, 2023 4:05 pm
Many people use UHMWPe strips rather than teflon. I got a piece several years ago from a skip that has served my needs for years, and recently my wife found a couple of cutting boards that were being tossed out that can also be sawed up into strips.
You can buy a 1/2 " X 6" X 36" piece of UHMWPe (commercial cutting board) from TAP plastics for about $25 that will make quite a number of strips: https://www.tapplastics.com/product/pla ... boards/346
Alternatively you can check if the local Walmart might have polyethylene plastic cutting boards in stock (or order a Farberware 11X14 poly cutting board from them for about $6) If you don't mind piecing strips in for purfling spacers.
PostPosted: Mon Mar 13, 2023 4:14 pm
Looking closer at the email in your post, I'm guessing you are looking for strips all ready cut, rather than being a hobby builder looking at them for personal use?
PostPosted: Tue Mar 14, 2023 1:08 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Deleted; you're looking for bulk
Measure Twice,
Karl Borum
PostPosted: Tue Mar 14, 2023 5:18 pm
McMaster Carr sells sheets of the material, and if you can find a cabinet shop in Southern Maryland that has a powered laminate slitting machine they may be able to cut it into strips for a reasonable price.
These users thanked the author Clay S. for the post: Pmaj7 (Tue Mar 14, 2023 5:26 pm)
