It is currently Sat Jun 13, 2026 12:28 pm
PostPosted: Thu Jan 13, 2022 4:56 pm
Has anyone tried making their own with a backwards spinning plywood blade and an angle grinder? I've seen it mentioned a few times and seems pretty straightforward. Maybe trickier than it sounds?
PostPosted: Thu Jan 13, 2022 6:24 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
What could possibly go wrong? Why take the risk? The Blade Mfg. Co. made me a 10” blade to my specifications for just over $100 a few years ago.
These users thanked the author bobgramann for the post: Pmaj7 (Thu Jan 13, 2022 8:43 pm)
PostPosted: Thu Jan 13, 2022 8:22 pm
I tried it. I didn't grind it down enough to really be effective. You have to go slow so as to not take the temper out of the blade.
I went with the 3 3/8th Makita battery saw blade (plain steel- not carbide tipped) and cobbled together a simple small "arbor saw" like a miniature version of those crude and dangerous saws farmers used to use. To adjust the depth of cut you raise one end of the table with shims.
I have also used the Makita battery saw to cut fret slots by hand (slower but quieter).
https://www.homedepot.com/p/Makita-3-3- ... /204382617
These users thanked the author Clay S. for the post: Pmaj7 (Thu Jan 13, 2022 8:43 pm)
PostPosted: Thu Jan 13, 2022 8:46 pm
Yeah, "what could possibly go wrong?" Lol that's what I'm thinking!
Clay, what's the kerf on those?
PostPosted: Thu Jan 13, 2022 10:23 pm
Hi Pat,
I don't remember exactly what the kerf measured, but the Stewmac wire works O.K. with it (.023?). If you find the kerf is too wide for your wire you can "stone" the blade lightly to narrow the kerf, and if it's too narrow you can bend the teeth slightly to increase it.
These users thanked the author Clay S. for the post: Pmaj7 (Thu Jan 13, 2022 10:25 pm)
Users browsing this forum: Bing [Bot] and 44 guests
