It is currently Fri Sep 19, 2025 1:02 am
PostPosted: Thu May 05, 2022 6:03 am
First name: CHARLES
Last Name: HENNET
State: PA
I see in piano and harp building it is common to dry the soundboard in a hot box before attaching the braces. You can also see Jonny Kinkead possibly doing something similar in the build series linked below:
https://www.youtube.com/watch?v=aAV9U3WzzP8
Dan's Acoustic Guitar Build Part 1/5 With Master Luthier Jonny Kinkead
Does anyone building here have an intentional heated drying session before gluing the braces?
Chuck
PostPosted: Thu May 05, 2022 6:22 am
Hard to find with no reference in your post to specific time /part - ?/5 no.
I bake my tops (and bracing) in a hot box (95-100 deg C 1.5 hrs) and leave them to re-acclimatize them before jointing the top and bracing it to pre-shrink and condition them (quite a common practice - taylor etc.), but would hesitate to heat the soundboard in a hot box before bracing because of the glue joint.
I've heard Martin used to keep their tops in a warm area (attic?) before bracing if that helps.
These users thanked the author Colin North for the post: davidson (Thu May 05, 2022 6:24 am)
PostPosted: Thu May 05, 2022 6:54 am
First name: CHARLES
Last Name: HENNET
State: PA
Thanks.
Kinkead video part 1 of 5 around 12:02.
PostPosted: Thu May 05, 2022 8:09 am
In a drying cabinet he says, looks like he's using a domestic a domestic air conditioner, maybe to feed dry air (which will be warm) into the drying cabinet.
PostPosted: Thu May 05, 2022 9:10 am
I have used an oven before but if you keep your wood in your controlled shop you should not have an issue with it imho.
PostPosted: Thu May 05, 2022 9:37 am
I bake all my tops just to get put them through the first cycle of shrinkage and let them acclimate before gluing on the braces. A world-class classical builder I know dries his tops to 3% and glues his braces with the tops still at 3%. When they acclimate to his shop humidity, they expand, forcing a dome.
PostPosted: Thu May 05, 2022 10:17 am
Pat, does he brace the top in a flat condition? Interesting.
PostPosted: Thu May 05, 2022 1:18 pm
Jim,
Couldn't tell you. If I get a chance, I'll ask him next time I see him.
PostPosted: Thu May 05, 2022 2:13 pm
Thanks!
PostPosted: Thu May 05, 2022 6:46 pm
First name: CHARLES
Last Name: HENNET
State: PA
Thanks all.
PostPosted: Fri May 06, 2022 5:24 am
Bracing in extremely low RH has been done by piano manufacturers, violin makers, mando makers and guitar makers. It's another approach to producing instruments that can withstand RH swings to a greater degree, hopefully. We think it's helpful but it's not anything new it's been done for a very long time and likely was done before we had machines to manipulate our environments by batching work and jobs for seasonal opportunities when the RH is right.
Users browsing this forum: TimAllen and 38 guests
