It is currently Thu Sep 18, 2025 8:49 pm
 Post subject: Serendipity
PostPosted: Tue Feb 21, 2023 6:02 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I cleaned up the Cello ribs today. The liners are glued in, but need to be tapered. I worked on getting the area of the bottom block where the original and replacement ribs joined together. I always think the join will be good, and it never is. I knew this one was going to be off, because when I was fitting it, it was too long. The plane when a little deep on the end, so I evened it out.
Yep, it has a mm gap. Way worse than normal. Usually you can just easily tell that it is there.
But the grain lines up like it was a one piece rib.I didn't even LOOK at the grain when I lined it up. Besides, it didn't have room to play around with the tapered ribs. So I cleaned out the glue from the gap, and glued in two, .5mm black purflings before lunch (dinner time) and I just went down, and planed and scrapped the extra mm or so off the black purfling. It looks great. It isn't the right way though, violin makers make perfect joins.
I never get them perfect. But the old masters didn't either.
They usually used on piece ribs on the upper and lower. No joins at all!
Why be normal?
These users thanked the author Ken Nagy for the post (total 2): bcombs510 (Tue Feb 21, 2023 7:42 pm) • Chris Pile (Tue Feb 21, 2023 7:34 pm)
 Post subject: Re: Serendipity
PostPosted: Tue Feb 21, 2023 7:10 pm
Sometimes it works out like that!
Users browsing this forum: Barry Daniels, Bing [Bot] and 48 guests
