It is currently Thu May 07, 2026 8:36 am
 Post subject: New Toy
PostPosted: Fri Dec 01, 2023 10:17 am
Last Name: Sollod
Gotta new 14" bandsaw, a Rikon 10-324TG. I love it! I managed without it, but it will open up more capabilty in my shop. It sure is nice to be able to re-saw. I found this 8/4 cherry board that is riddled with figure. I setup and adjusted the saw and let'r rip.
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post (total 4): Kbore (Fri Dec 01, 2023 6:08 pm) • SteveSmith (Fri Dec 01, 2023 1:27 pm) • Michaeldc (Fri Dec 01, 2023 12:20 pm) • bcombs510 (Fri Dec 01, 2023 10:17 am)
 Post subject: Re: New Toy
PostPosted: Fri Dec 01, 2023 10:23 am
First name: Brad
Last Name: Combs
Nice! I have the previous model and have enjoyed it. I pair it with the woodslicer blades from Highland for resaw. It’s a good middle ground cost / performance and I can get decent yield.
I think your version has the quick adjust bearings, mine did not. However I replaced the bearings with these based on a recommendation from Michael Colbert and they are great. Easy enough to adjust and kinder to the blade than the bearings were - https://www.spaceageceramics.com
Last thing - I bought these recently for both of my bandsaws (14” and 10”). They are awesome and do work. I thought for sure it was a gimmick, and it might be, but they are working for me. :) - https://www.eztension.com/buy-one-now/e ... tification
Brad
PostPosted: Fri Dec 01, 2023 10:24 am
Last Name: A
That's a nice looking set. Resawing is fun - makes you find wood and get more creative. My saw can only do 6" width - so I have have to plan a lot of 3 piece or 4 piece backs.
PostPosted: Fri Dec 01, 2023 10:47 am
Last Name: Sollod
Thanks for the tips Brad. Could you take a quick photo of your guide bearings? Are you using flat or round? Do the round ones rotate?
PostPosted: Fri Dec 01, 2023 11:01 am
Last Name: Sollod
I was doing 3-piece backs when I found a board I wanted to use. I would run the board through my table saw, turn it over and run it through again and then use a hand saw or recipricating saw to cut what was left. That sucked! pfft No more! bliss Here is an example where I built the entire guitar out of one board (except the top, of course).
https://www.swiftcreekguitars.com/maple-om.html
PostPosted: Fri Dec 01, 2023 11:29 am
First name: Brad
Last Name: Combs
This is what I have. You might shoot them a mail because it looks like they have new products since I ordered these.
PostPosted: Fri Dec 01, 2023 12:29 pm
Last Name: Ball
Brad
+1 on the Eztension. Those things work great.
These users thanked the author ballbanjos for the post: bcombs510 (Fri Dec 01, 2023 2:28 pm)
PostPosted: Fri Dec 01, 2023 2:13 pm
5 slices per inch or bust!
These users thanked the author meddlingfool for the post (total 2): bcombs510 (Fri Dec 01, 2023 6:34 pm) • Kbore (Fri Dec 01, 2023 6:10 pm)
PostPosted: Fri Dec 01, 2023 2:28 pm
First name: Brad
Last Name: Combs
I get that but after ~15 slices I’m changing blades. :D
These users thanked the author bcombs510 for the post: Kbore (Fri Dec 01, 2023 6:10 pm)
PostPosted: Fri Dec 01, 2023 4:18 pm
Really? After only 15 cuts? The Laguna Resaw King perform substantially better than that and runs on 14” wheels…
PostPosted: Fri Dec 01, 2023 4:58 pm
First name: Brad
Last Name: Combs
Depends on the material but 15-20 would be my estimate, I’ve never really counted super closely.
Yes, but I can get 4 of the woodslicer blades for the cost of a resaw king. Of course the resaw king can be sharpened so long run it would have to work out better I assume. I don’t know what it costs to have it sharpened.
But for what I do quantity wise the woodslicer is perfect. :)
PostPosted: Fri Dec 01, 2023 6:11 pm
Online
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
When I had a 14” saw, I used the woodslicer blades to cut Osage Orange. I could cut about 15 feet before the blade had to be resharpened. I could sharpen the blade 3 times before the geometry was ruined and I had to start a new blade. I upgraded to a Rikon 18” saw and a Woodmaster CT blade. The carbide blades often last me more than a year. I have no idea how far I cut in a year. The downside is the wider kerf—almost 1/16”, but it’s worth a little waste not to have to replace the blade so often. I don’t know how the carbide blade would work on a 14” saw.
My old 14” saw (a Delta clone) doesn’t compare well to your new Rikon. The cast frame was fairly flexible making a heavy cut difficult. I let the smoke out of the first motor. When I upgraded to a 1 hp motor, the frame complained under the load. Moving to a bigger saw helped a lot.
These users thanked the author bobgramann for the post: bcombs510 (Fri Dec 01, 2023 6:34 pm)
PostPosted: Fri Dec 01, 2023 8:10 pm
I think the RK blade is the only one that can run on 14” wheels…
PostPosted: Fri Dec 01, 2023 8:37 pm
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
Timberwolf has a “veneer cutting blade” that works great on my Delta 14” saw (with riser block). I’ve only made a few resaw cuts with it so far but already I’ve had better results than I got with the wood slicer. Caveat: maybe I just did a better job of saw setup this time around, but in any case, I like the Timberwolf blade.
ttps://www.timberwolfblades.com/proddet ... od=1234VPC
These users thanked the author bionta for the post: bcombs510 (Fri Dec 01, 2023 8:47 pm)
PostPosted: Fri Dec 01, 2023 8:50 pm
First name: Brad
Last Name: Combs
Link doesn’t seem to work, missing the hyper ;). Is it this one? https://www.timberwolfblades.com/prodde ... od=1234VPC
PostPosted: Fri Dec 01, 2023 8:51 pm
I think I should have said only carbide one…
These users thanked the author meddlingfool for the post: bcombs510 (Fri Dec 01, 2023 9:27 pm)
PostPosted: Fri Dec 01, 2023 9:11 pm
Last Name: Ionta
City: Hopkinton
Sorry - sloppy cut/paste. You’ve got the correct link. Thanks for the correction.
These users thanked the author bionta for the post: bcombs510 (Fri Dec 01, 2023 9:26 pm)
PostPosted: Fri Dec 01, 2023 10:31 pm
Nice saw and beautiful cherry wood. I love that wood for guitars.
I guess I need to think about sharpening my blades. I've run way more than 15 feet through mine that's for sure.
PostPosted: Sat Dec 02, 2023 12:11 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
How do you sharpen them? Dremel in a jig? Send them off to someone?
PostPosted: Sat Dec 02, 2023 2:28 pm
Online
Last Name: Gramann
State: VA
I think Alan Carruth explained this many years ago, so if I get this wrong, maybe he’ll come in and correct me. I sharpen the bimetal, thin kerf blades on the saw (unplugged, of course). Lift the guide to expose as much blade as possible. Mark the blade so you know when you’ve gone all the way around. What you want to do is make the very tip of the blade sharp again. I use the abrasive disk on a Dremel freehand with no jig. Each tooth has set—it’s bent slightly to one side or the other. As you’re facing the saw, you’ll cut the top of the tooth perpendicular to that set so that the dull tip is cut back until it’s sharp. It takes just a touch on each tooth to do this. If you mess up the angles, the blade will curve to one side or the other when it’s cutting. It’s pretty easy to advance the blade by hand to expose the next few teeth. Doing the whole blade takes very few minutes.
Since you’re shortening the tooth, after about three resharpenings the gullet starts to be reduced so that the blade can’t carry away the sawdust as well and cuts badly. But, you’ve saved yourself from buying 3 blades by then.
I haven’t tried resharpening a carbide blade yet. My Woodmaster CT (Lenox) doesn’t have a set. The kerf is formed by the attached carbide tips which are wider than the blade. These blades last so long that I figure they don’t owe me anything and I just replace them when the cut starts going awry.
These users thanked the author bobgramann for the post (total 2): Pmaj7 (Sun Dec 03, 2023 10:32 pm) • CarlD (Sat Dec 02, 2023 6:25 pm)
PostPosted: Sat Dec 02, 2023 2:33 pm
I send out. Laguna used to do it themselves but now they don’t, I think the last time I had it done local it was 70CAD per. Each RK blade can be sharpened 4 times. When I bought them they were 250CAD. I’d say I’m ten year in on the blades and only on the second resharpened one. I bought 4. The RK blade resides as a permanent resident on my SUV and now 90% of my straight cuts are done with it…
These users thanked the author meddlingfool for the post (total 2): Durero (Wed Dec 06, 2023 10:52 pm) • CarlD (Sat Dec 02, 2023 6:25 pm)
PostPosted: Sun Dec 03, 2023 11:33 pm
What kind of actual kerf are you getting with that blade?
Sent from my SM-N960U1 using Tapatalk
PostPosted: Mon Dec 04, 2023 1:51 pm
Last Name: Ionta
City: Hopkinton
I didn't measure and I have a different blade on the saw right now, but I'd say it was just about the same as the kerf with the 1/2" Woodslicer of similar specs.
These users thanked the author bionta for the post: Pmaj7 (Mon Dec 04, 2023 2:12 pm)
Users browsing this forum: bobgramann and 8 guests
