It is currently Tue May 05, 2026 5:49 am
 Post subject: Sanding Zipflex
PostPosted: Sun Dec 24, 2023 3:39 am
First name: Thomas
Last Name: T
I’m considering using some zip flex abalone, but I am unsure if it is sandable.
On my first guitar, I had to sand the abalone, and I am unsure if the zip flex can be sanded or not.
If not, what is the technique for installing? Set it below the surface of the wood and sand the wood down even?
 Post subject: Re: Sanding Zipflex
PostPosted: Sun Dec 24, 2023 4:23 am
First name: Martin
Last Name: Taylor
City: Central Coast
Zipfkex is real she’ll so can be sanded. There is the same health risk so make sure you have adequate protection.
Martin Taylor
http://martintaylorguitars.com.au
PostPosted: Sun Dec 24, 2023 5:07 am
I try to install it as close to level with the wood surface as possible, just a few thousandths above, to minimize sanding but otherwise no issues. Image
These users thanked the author SteveSmith for the post (total 3): Pmaj7 (Wed Dec 27, 2023 3:01 pm) • bcombs510 (Sun Dec 24, 2023 2:30 pm) • guitarmaker78 (Sun Dec 24, 2023 12:57 pm)
PostPosted: Sun Dec 24, 2023 12:57 pm
First name: Thomas
Last Name: T
Appreciate the feedback.
These users thanked the author guitarmaker78 for the post: Kbore (Sun Dec 24, 2023 5:21 pm)
PostPosted: Sun Dec 24, 2023 5:20 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
The chatoyant part of the zip flex I used was thin on some sections. You want to do minimal sanding.
Measure Twice,
Karl Borum
PostPosted: Sun Dec 24, 2023 8:13 pm
I've only used it twice but never had a problem sanding it. As mentioned keep your tolerance tight but I do that with regular abalone too
PostPosted: Wed Dec 27, 2023 6:34 pm
First name: David
City: Napa
Zip/Postal Code: 94558
If possible I try and have the Zipflex a few thousands lower and fill with CA glue. Sanding the zipflex makes me nervous
These users thanked the author dofthesea for the post: Pmaj7 (Thu Dec 28, 2023 9:57 am)
PostPosted: Thu Dec 28, 2023 3:42 am
First name: Thomas
Last Name: T
Sounds like a good strategy.
