It is currently Fri May 01, 2026 6:58 pm
 Post subject: spraying shellac
PostPosted: Mon Mar 04, 2024 3:21 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
has anyone done a 100% shellac spray finish (what cut & nozzle size)? And what is your final buff routine. Have you seen any tutorials out there.
Mike McNerney
These users thanked the author mikemcnerney for the post: bcombs510 (Tue Mar 05, 2024 11:49 pm)
 Post subject: Re: spraying shellac
PostPosted: Mon Mar 04, 2024 7:04 pm
The biggest headache with spraying shellac is cleaning the gun afterward. Shellac seems to get in the spaces other finishes don't find and gum up the gun.
If you have a nice spraygun you might want to buy a cheap HF jamb gun for shellac that you can soak in a bucket of alcohol.
Sprayed shellac dries more slowly than French polish or lacquer and if sprayed in a dusty environment seems to acquire a fur coat.
These users thanked the author Clay S. for the post: bcombs510 (Tue Mar 05, 2024 11:49 pm)
PostPosted: Tue Mar 05, 2024 11:47 pm
Last Name: Livermore
State: Minnesota
Shellac is forgiving. It can be applied just about any way you can dream.
But lacquer, it is not.
Very different beasts.
Sure it can be done, but with all other luthierie finishing processes, practice on scrap.
The biggest woes I encountered were the flash off rates of the solvent. With a lot of air shooting the medium out of the gun, the alcohol was gone before it hit the wood.
So, dial back the air as much as possible and practice away. (It’s about as cheap finish as they come)
Come to think of it, I have to wonder… why do you want to spray it?
Once learned, french polish is pretty easy and quick.
These users thanked the author Dave Livermore for the post: bcombs510 (Tue Mar 05, 2024 11:49 pm)
PostPosted: Tue Mar 05, 2024 11:55 pm
First name: Brad
Last Name: Combs
To your specific question about gear, I use 1mm fluid tip with the gun set to 25psi when triggered. 1lb cut. 4” pattern at 4” distance.
These are the settings I use when “toning” while spraying a burst, which is pretty much just laying a full overlapping coat down but with stain in it.
Hope that helps.
Brad
PostPosted: Wed Mar 06, 2024 6:44 am
For my Walcom HVLP I use a 1.2mm tip, 27 psi, 1lb cut. Like Brad, a 4” pattern at about 4”.
Given that, I prefer to French polish.
These users thanked the author SteveSmith for the post: bcombs510 (Wed Mar 06, 2024 8:27 am)
PostPosted: Thu Mar 07, 2024 12:21 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I'm lazy - - - Zinsser rattle can dewaxed shellac.
Peter Havriluk
PostPosted: Sat Mar 16, 2024 7:02 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
I was curious to see if anyone had anything to say about buffing shellac. I guess I have always assumed that shellac is too soft to buff.
Shellac is easy to use, the solvent fumes are benign, and the whole process is friendly to hobby building where you are learning as you go. But in my opinion, once you have the shellac perfect and the guitar has all the bugs worked out of it, it is worth it to put a thin layer of lacquer on top. Shellac wears away where the hands touch the instrument. Lacquer has a traditional gloss and is more scratch-resistant than shellac.
PostPosted: Sat Mar 16, 2024 8:14 am
First name: Craig
Last Name: Wilson
City: Richmond
I buff my french polished shellac by hand with Novus 2 Fine Scratch Remover.
I wipe it on a small area at a time (maybe 6" x 6") with a Scott shop towel and buff in circles. Dry any remaining compound to a haze and wipe off with a clean dry towel.
Craig
________________________________
Luthiers can happen even in the best of families. No one knows why. ;-)
These users thanked the author Craig Wilson for the post: bcombs510 (Sat Mar 16, 2024 8:47 am)
PostPosted: Sat Mar 16, 2024 8:35 am
First name: R.M.
Last Name: Mottola
My setup is exactly the same as Brad's. I rarely spray shellac though, because as Dave points out, it flashes off very fast if only alcohol is used as a solvent, and that makes it a lot tougher to spray. Using lacquer thinner as the solvent instead (or adding toluene and xylene to the alcohol, same difference) gums things up.
To increase build and hardness, a number of folks I know have experimented with adding resins like sandarac, but at some quantity that gets into the range of spirit varnishes. Both Robert Ruck and Federico Sheppard liked to add a little lacquer to shellac (one of them, can't remember which) called that combination shellaquer. But there again, the material has at least some nasty toluene and xylene in it, and if you have to up your personal protection game because of that, then straight lacquer becomes more appealing.
R.M. Mottola
LiutaioMottola.com
Author of the books Building the Steel String Acoustic Guitar, Practical Design of the Acoustic Guitar and Similar Instruments, and Mottola's Cyclopedic Dictionary of Lutherie Terms.
I don't check in here very often. If you need to contact me the best bet is via email through the contact page on my site.
These users thanked the author rmmottola for the post: bcombs510 (Sat Mar 16, 2024 8:48 am)
PostPosted: Sat Mar 16, 2024 8:49 am
If you want a "high build" shellac finish, you can brush it on, sand it smooth after it dries , and French polish the last couple of coats. It doesn't seem to give the same results as a thin French polished finish, but it can be less work.
