It is currently Wed Jul 30, 2025 10:52 pm
PostPosted: Tue Jun 04, 2024 4:30 pm
First name: Jon
Last Name: Snider
City: Colorado Springs
State: Colorado
I’m considering routing out the binding and purfling on the treble side of my guitar. I left the binding too proud and scraped partly into the next layer. It doesn’t look too bad now with some touch up dye but up until now I’ve been very happy with this build and I know this is going to bother me down the road.
I used CA glue. Anything I need to consider different than usual if I rout everything out and start over?
thanks. Jon
PostPosted: Tue Jun 04, 2024 4:42 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I'd be interested in this myself.
Hutch
PostPosted: Tue Jun 04, 2024 4:55 pm
City: U.P.
If during the scraping/sanding/leveling of original sides and bindings, the actual side surfaces were changed. And I don't know how they would not be altered in the process. Then the new binding and purf channels probably won't match up with the bass side of the guitar.
You might be able to finesse the new channels to match up but it might just be easier to rout new purf channels and binding channels for the whole top or back. Hoping your problem doesn't effect both top and back.
You could try setting router depth/width so that it matches the bass side and try that first. Probably what I'd do.
I'm just betting your original routing schedule will not match up with the bindings you want to save.
Good luck with the save! pics would help.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post (total 2): Hesh (Wed Jun 05, 2024 4:17 am) • Duct Tape (Tue Jun 04, 2024 7:25 pm)
PostPosted: Tue Jun 04, 2024 7:25 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I’ve routed binding off before. Nothing stands up to a router. In case it makes a difference: CA glue is often susceptible to heat. It won’t take much warming for the glue to fail so you can easily pull off what you have.
These users thanked the author bobgramann for the post: Duct Tape (Tue Jun 04, 2024 7:26 pm)
PostPosted: Tue Jun 04, 2024 7:28 pm
First name: Jon
Last Name: Snider
State: Colorado
Just the treble side top installed so far.
I might try heat as mentioned in next post. But eventually I’m going to need to slightly deepen both binding and purf channels. Or use thinner material.
Thx
PostPosted: Tue Jun 04, 2024 7:32 pm
I have also routed binding off before but only once. I set the bit for full depth and height of the binding. When I started routing some of the binding blew off in chunks and took some little pieces of side with it. If I do it again I will use multiple, shallower cuts.
These users thanked the author SteveSmith for the post: Hesh (Wed Jun 05, 2024 4:18 am)
PostPosted: Tue Jun 04, 2024 7:50 pm
First name: Jon
Last Name: Snider
State: Colorado
Thanks Steve. I was wondering exactly the same thing.
PostPosted: Wed Jun 05, 2024 12:20 am
Climb cut all of it.
These users thanked the author meddlingfool for the post: Duct Tape (Wed Jun 05, 2024 7:19 am)
PostPosted: Wed Jun 05, 2024 2:32 pm
First name: Jon
Last Name: Snider
State: Colorado
Any thoughts about effectiveness of heat on releasing CA glue joint?
With a hair dryer. I don’t gave the cahones to use a heat gun next to all that wood!
PostPosted: Wed Jun 05, 2024 2:37 pm
Even if you heat release it, you’ll still have to clean up all the glue residue. Just route it off with a climb cut and you’re ready for another go…
These users thanked the author meddlingfool for the post: Duct Tape (Wed Jun 05, 2024 6:03 pm)
PostPosted: Wed Jun 05, 2024 2:53 pm
Last Name: Gramann
State: VA
I use a little hobby iron for stuff like that. I stole it from my son who use to use it to shrink fabric on his RC planes.
PostPosted: Wed Jun 05, 2024 4:30 pm
The top I cut the binding off of was on guitar #2. So long ago I don't remember if I used a climb cut or not - possibly not.
PostPosted: Wed Jun 05, 2024 4:55 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I have done it too. As suggested, climb cuts and in a few passes, will get the job done safely.
These users thanked the author Mark Mc for the post: Duct Tape (Wed Jun 05, 2024 6:03 pm)
PostPosted: Fri Jun 07, 2024 4:26 pm
Just had to do this today. Not the first time but looking at this was a good reminder to climb cut the whole way. It pushes the binding into the guitar instead of trying to rip it out.
Came out great but shouldn’t have had to do it. Bummer.
These users thanked the author Jim Watts for the post: Duct Tape (Fri Jun 07, 2024 5:50 pm)
